larrynimmo Posted October 17, 2022 Report Posted October 17, 2022 Does anyone know the simplist way to change the light bulb? m20j gear down indicator
rotorman Posted October 18, 2022 Report Posted October 18, 2022 It's been a few years since I changed mine, but I recall it's pretty straight forward from under the airplane. Unscrew it and change the bulb. I don't recall any issues.
Ragsf15e Posted October 18, 2022 Report Posted October 18, 2022 Thought we had a thread discussing getting to the bulb from the top - i.e. from the cockpit?
carusoam Posted October 18, 2022 Report Posted October 18, 2022 How many MSers does it take to change a light bulb? Let the count begin… Best regards, -a- 2
Guest Posted October 18, 2022 Report Posted October 18, 2022 17 hours ago, larrynimmo said: Does anyone know the simplist way to change the light bulb? m20j gear down indicator Normally there is a small retainer nut which holds the bulb in place. A 5/16” ignition wrench is helpful in removing the nut. It’s under the lens in your picture, the light socket stays in place.
N201MKTurbo Posted October 18, 2022 Report Posted October 18, 2022 I’ve never done it, but here is how I would do it. loosen the nut holding the socket then unscrew the nut till it slides down the wire . Then push the socket up and out of the bracket. The. It will be hanging down so you can get to the bulb.
Guest Posted October 18, 2022 Report Posted October 18, 2022 4 hours ago, N201MKTurbo said: I’ve never done it, but here is how I would do it. loosen the nut holding the socket then unscrew the nut till it slides down the wire . Then push the socket up and out of the bracket. The. It will be hanging down so you can get to the bulb. That works as well, until the socket turns and twists off the wire.
EricJ Posted October 18, 2022 Report Posted October 18, 2022 I just did this fairly recently (within the last year, anyway), and I don't remember the detail but getting the bulb changed was the easy part.
N201MKTurbo Posted October 18, 2022 Report Posted October 18, 2022 1 hour ago, M20Doc said: That works as well, until the socket turns and twists off the wire. Why would the socket turn?
mooniac15u Posted October 18, 2022 Report Posted October 18, 2022 The retaining nut on top was only finger tight on mine. The bracket flexes a little so I was able to remove the nut and bulb without a wrench.
Guest Posted October 18, 2022 Report Posted October 18, 2022 3 hours ago, N201MKTurbo said: Why would the socket turn? Not everyone is as skilled as you and I! I’ve learned that where a mistake can be made, someone will find a way to do it, costing someone time and money to correct.
A64Pilot Posted October 18, 2022 Report Posted October 18, 2022 I’m thinking this is easier than we suppose, I’ve not done it but think bending an ignition wrench will get it loose, then it’s just spin it with my fingers, then replace bulb and tighten with fingers, snug with wrench. I’ve got an LED that will I believe be brighter, and last forever
carusoam Posted October 19, 2022 Report Posted October 19, 2022 7 hours ago, A64Pilot said: I’ve got an LED that will I believe be brighter, and last forever Keep in mind… This bulb is often a 24V bulb in a 12V application that produces a dimmed output intentionally… People that fly in the dark must appreciate the low output bulb… PP thoughts only… Best regards, -a-
A64Pilot Posted October 19, 2022 Report Posted October 19, 2022 It’s only lit when the gear are down? I’ll get over it. ‘Isn’t it dimmed when the position lights are on? If so mind are always on due to my ADSB
PT20J Posted October 19, 2022 Report Posted October 19, 2022 48 minutes ago, A64Pilot said: It’s only lit when the gear are down? I’ll get over it. ‘Isn’t it dimmed when the position lights are on? If so mind are always on due to my ADSB Floor light is powered by the gear down limit switch. It doesn't dim -- only the gear down light on the annunciator panel dims with nav lights.
flyboy0681 Posted October 20, 2022 Report Posted October 20, 2022 On 10/19/2022 at 1:29 AM, carusoam said: Keep in mind… This bulb is often a 24V bulb in a 12V application that produces a dimmed output intentionally… People that fly in the dark must appreciate the low output bulb… PP thoughts only… Best regards, -a- True the LED is very bright, but a quick glimpse will confirm whether it's illuminated or not. Years ago I had an issue with the Gear annunciator light and looking down during daytime didn't help the situation since the floor bulb was so dim. Now there's no doubt, and if it's too bright for night flying, it can be easily covered. 1
Fly Boomer Posted October 20, 2022 Report Posted October 20, 2022 16 minutes ago, flyboy0681 said: True the LED is very bright, but a quick glimpse will confirm whether it's illuminated or not. Years ago I had an issue with the Gear annunciator light and looking down during daytime didn't help the situation since the floor bulb was so dim. Now there's no doubt, and if it's too bright for night flying, it can be easily covered. Click and Clack The Tappet Brothers, advised a piece of electrical tape to cover an idiot in some circumstances. I like your idea.
flyboy0681 Posted November 17, 2022 Report Posted November 17, 2022 On 10/20/2022 at 5:39 PM, flyboy0681 said: True the LED is very bright, but a quick glimpse will confirm whether it's illuminated or not. Years ago I had an issue with the Gear annunciator light and looking down during daytime didn't help the situation since the floor bulb was so dim. Now there's no doubt, and if it's too bright for night flying, it can be easily covered. Finally remembered to take a picture while on the ground. Replacing the dim incandescent with a bright LED has made the task of checking the gear so much easier. 5
Z W Posted November 18, 2022 Report Posted November 18, 2022 Nice improvement with the LED, I should do that too. The 1982-vintage plastic covering our gear indicator light had gotten cloudy, scratched up, and faded, like yours is a bit. It was getting hard to read the indicator during the day, although you could tell if it was red or green under there. I spent 2 minutes polishing it with some polishing compound and a damp cloth and it cleared right up. Might help also.
