I just completed my first transcon. from KSMO to KOWD and am looking to do an oil change before I head back to LA. I'm searching for oil filters (48103-1 or aa48103-2) but everything is on back order. Does anyone know where one can be found? I'm trying to head west 10/24 but I also want to fly while I'm here in New England. My current oil has about 18 hours on it and I need to change around 25h. I'm doing the 25h intercal as I just got a new engine so this is the break in oil. I broke the engine in, changed oil after 7 hours, and have now put 18 hours on this current oil and filter. 25 total on the new engine but only 18 on the oil/oil filter.
Anyways, if anyone has a lead on where to find a filter or would be willing to part ways with one, I would be very appreciative and would compensate accordingly.
All the best,
TR
There is a whole thread on filter availability around here…
Find it… and you will find sources and people that have filters…
The supply chain issues are getting much better lately…
I keep hearing that, so I ordered a filter from Aircraft Spruce.  The web said expected ship date was a couple of weeks out -- confirmation that our supply chain issues are about over.  When I didn't hear anything from Spruce, I called to inquire when I could expect my order to arrive.  Woman I talked to said they get very few filters, and those go to people who have had orders in the system for more than a year.  She also said not to expect anything this year.
All the best,
TR
A 48104 series filter will fit your engine as well.
Much better… not perfect.   :)
Thank you! I managed to find 2 aa48103-2 series filters. Thank you all for the help!
6 hours ago, mikey757 said:
Anyone know which Tempest filter replaces the Champion 48103-1
As far as I can tell, the numbers are the same between Champion and Tempest, except you add AA to the beginning for Tempest.
So Champion 48103-1 becomes Tempest AAA48103
So Champion 48101-1 becomes Tempest AAA48103
Wouldn't that be an AA48101 (if either company actually made a 48101, which they don't)?
TYPO. :)
I just got mine yesterday from AircraftSpruce. I ordered it 2 months ago to make sure I had it before Annual later this month :-)
If your engine is an IO360-A1B6D or IO-360-A3B6D you can use either version of the 48103 short filter or 48104 long filter.
At 25 hours and no filter available I would change the oil and check the oil pump screen. If the oil pump filter screen is clear then order a 6-pack of Tempest oil filters and crush rings for the oil pump screen and you are good for the next couple of years.
