I had asked that question a while ago as I'm moving to Spokane in the not to distant future....
Western Aviation has several mechanics on staff (509-534-7371).
Joe Arcuri is an independent mechanic that apparently has a good reputation.  I would think the Airport Manager might have his number or you can find him on LinkedIn and can send a message there.  Be sure to add KSFF to get the right one. (e.g.  Joe Arcuri KSFF)
And I know there's a Mooney guy at Coeur d'Alene (KCOE), but not sure what I did with his info.  It might be Coeur d'Alene Aviation and Maintenance (208-635-0805), but I'm not sure.
31 minutes ago, mooneyflyer said:
Fellow Mooniac is AOG in Spokane. Anyone recommend a good mechanic?
I live in Spokane.  Western Aircraft closed its maintenance Operation (and avionics).  They are only an fbo now.  Pete Reed at NW Flight Service is who you want.  He’s got a couple other IAs working with him. Usually busy, but I did my oil change in his hanger this week and it wasn’t too full.  Not cheap, but he’s good.
What’s broken?
4 hours ago, mooneyflyer said:
Just helping out a fellow Mooniac.
Did your friend get things worked out?  I'd love to hear a PIREP as I'm going to be needing a good Spokane area mechanic in the not to distant future.
Stay away from Coeur 'd Alene Maintenance and Aviation.
Wise Aircraft Maintenance in Kellogg does all the work on my plane.  Dustin Wise is thorough and reasonable.
I'm close by, how can I help?
