Do you push/pull on prop to move plane on the ground?
49 members have voted
  1. 1. Do you push/pull on prop to move plane on the ground?
    • 45
    • 4
The results may be skewed by the wording of the poll.  Anyone who answers is defacto admitting to be a "prop tugger."  Probably too late now to change it to "Prop Tugging Poll" I guess to concentrate on the activity and not those apparently doing it.Wink
"Now Joshua, if you don't stop pulling on that prop, you will go blind!!"
Yes, my name is sleepingsquirrel,and I am a prop tugger. We should have a long discussion about never turning a prop because the engine will start every time. My Mooney will start if I even touch the spinner with any tangential force. It's such a sure thing I took my starter off. Wink
Ok, 20 out of 20 people vote that it's safe to move a Mooney by the prop 100%. Then why in another topic did it seem like there was a major disagreement about it and that opinions were all over the place?
I try to avoid having to pull on most things affixed to any airplane including the prop.  Have I done it, sure and it still flies that doesn't mean I make a habit out of it.  The problem with old wives tales is you never hear the other side which are the people who always do X and then explain away impact Z.  Are you wings leaking because you landed on grass 1000 times or are they leaking due to age, hard to really say for sure which is which thus anything you can do in my opinion to minimize hurt to the aircraft (within reason).
In my opinion in life, flying, and owning an airplane there are few if any absolutes.
Close to the hub only; never further out on the blade. Only myself or a known trusted person.  And I still watch them. I am the one flying the plane who ultimately pays the price (and the bills).
Jim
AC 20-37E
Date: 9/9/05
300.  PROPELLER BALANCING.  This section describes only the general issues and types of
propeller balancing.  It is not intended to provide instructions for maintenance personnel to
perform static or dynamic propeller balancing.
a.  Unbalance.
(1)  Propellers can become unbalanced during operation from mishandling, wear, damage
and a variety of other causes.  In some instances, the process of moving an aircraft by pushing or
pulling on the propeller blades has bent or unseated the blades to an out-of-track condition or
damages the blade preload system.  Propeller wear and damage - and the repair of that damage -
are also contributors to propeller imbalance.  Unauthorized or improper repair of propeller
spinners has also been identified as a cause of propeller imbalance.
This is quoted from: AC 20-37E
Date: 9/9/05
So I did, but now I don't. Should add that in the poll question.
Quote: 201er
I didn't realize this would be such a mathemetically sophisticated topic that it would stir such intellectual debate beyond mortal comprehension so now I'm curious if a majority does or does not handle plane by the prop on the ground. I couldn't add a poll to the original topic so I guess just keep discussing it there but find out where we stand on this poll.
