M20J-Uwe Posted July 13, 2022 Report Posted July 13, 2022 Hi Guys, I’m looking for a M20J boost pump Pn:A8163-B Fuel Pump-Weldon. Seems very difficult to get one. Any hint or suggestions? Tks Quote
Ragsf15e Posted July 13, 2022 Report Posted July 13, 2022 On 7/13/2022 at 12:43 PM, M20J-Uwe said: Hi Guys, I’m looking for a M20J boost pump Pn:A8163-B Fuel Pump-Weldon. Seems very difficult to get one. Any hint or suggestions? Tks Expand Do you have a core? Aeromoters can overhaul yours quickly. Quote
Marauder Posted July 13, 2022 Report Posted July 13, 2022 On 7/13/2022 at 12:43 PM, M20J-Uwe said: Hi Guys, I’m looking for a M20J boost pump Pn:A8163-B Fuel Pump-Weldon. Seems very difficult to get one. Any hint or suggestions? Tks I don’t see a “B” variant of the 8163 listed at Aircraft Spruce. The “A” version is out of stock. Have you tried contacting Weldon directly to see if they can overhaul your unit? They offer rebuilt units, maybe that is the solution. Sent from my iPhone using Tapatalk Pro Quote
M20J-Uwe Posted July 13, 2022 Author Report Posted July 13, 2022 On 7/13/2022 at 1:19 PM, Ragsf15e said: Do you have a core? Aeromoters can overhaul yours quickly. Expand Thank you. Yes, I do have the defect pump. Do you have any contact information? EASA certificate for overhaul may be an issue. Quote
ArtVandelay Posted July 13, 2022 Report Posted July 13, 2022 On 7/13/2022 at 3:33 PM, M20J-Uwe said: Thank you. Yes, I do have the defect pump. Do you have any contact information? EASA certificate for overhaul may be an issue.They mention they are both FAA/EASA certified. Quote
M20J-Uwe Posted July 13, 2022 Author Report Posted July 13, 2022 I found the contact information and contact them. Let’s see. Tks Quote
Fly Boomer Posted July 13, 2022 Report Posted July 13, 2022 On 7/13/2022 at 3:33 PM, M20J-Uwe said: Do you have any contact information? Expand Aeromotors, LLC 304 E. Murray St. Browntown, WI 53522 United States 608-966-3141 http://aeromotorsllc.com/ Aeromotors LLC is a FAA / EASA certified repair station Quote
M20J-Uwe Posted July 13, 2022 Author Report Posted July 13, 2022 On 7/13/2022 at 1:21 PM, Marauder said: I don’t see a “B” variant of the 8163 listed at Aircraft Spruce. The “A” version is out of stock. Have you tried contacting Weldon directly to see if they can overhaul your unit? They offer rebuilt units, maybe that is the solution. Sent from my iPhone using Tapatalk Pro Expand Thank you. Will contact Weldon too. Great help from you guys. Not as easy to get spare parts in Europe. 1 Quote
M20J-Uwe Posted July 13, 2022 Author Report Posted July 13, 2022 On 7/13/2022 at 3:55 PM, M20J-Uwe said: Thank you. Will contact Weldon too. Great help from you guys. Not as easy to get spare parts in Europe. Expand Regards the variant, it a B-Variant. On 7/13/2022 at 1:21 PM, Marauder said: I don’t see a “B” variant of the 8163 listed at Aircraft Spruce. The “A” version is out of stock. Have you tried contacting Weldon directly to see if they can overhaul your unit? They offer rebuilt units, maybe that is the solution. Sent from my iPhone using Tapatalk Pro Expand It’s a 8163-B. Quote
