Just try to go out and buy a new battery! There is no stock available for your typical lead acid wet battery. There is stock for dry batteries but no acid available apparently there’s a worldwide shortage of sulfuric acid. Anybody got any acid they wanna part with?
I even thought about using automotive battery acid the thought being that acid is acid but automotive battery acid is 1.265 versus aviation batteries which are 1.285 specific gravity. apparently most of the sulfuric acid for batteries is produced from Chilean zinc.
Your probably about the first person I’ve spoken to that knew aircraft batteries require a stronger acid.
Having said that stay away from wet batteries, fly long enough and one will leak on you and that acid isn’t kind on aircraft materials
Look around and you can eventually find a concorde rg-35axc (if you’re 12V) at one of the smaller aviation suppliers.  That’s what you want.  I wouldn’t mess with anything else unless yours is totally dead.
This link at the concorde site says “distributors with stock”.  You might just need to start dialing…
https://www.aircraft-battery.com/search-by-your-aircraft/battery_detail/159
Yeah I went to the battery box and the box was empty, it wouldn’t have mattered the aircraft hadn’t moved in 15 years!
So my dilemma is get the airplane somewhat close to airworthy and able to test the motor
Better that it was empty then because that could have been bad if some acid leaked.  I think you’ll find a Concord if you call around.
Could it just be because it’s an unpopular type of battery today? The only reason I’ve heard for those batteries even still being sold in the last 10 years is because low volume sellers can shelve them longer
However for just determining if the engine would run after 15 years of sitting, I believe I just connect jumper cables from my car to the battery wires, or maybe use a car battery. Not to fly with of course just for testing.
Sounds like this could be a big project and those sometimes take a long time, don’t pop $400 on a battery until you know what you have
Of course pre-oil the motor well before you turn the prop
First time it ever loaded a picture upside down? I even saved the picture upside down and tried to insert but it was still upside down!?
Yeah, it’s beyond me.
‘Usually someone will fix it, it’s not just you
What I was trying to say is before you drop $400 on a battery that could possibly be sitting on a shelf for awhile, use a car battery etc for ground runs and drop the $400 when you think your close to flying
