So I’m looking for information on a particular prop and do I need an eddy current every year or visual every year I’m not clear on this my prop model is a HC – C2YK - IBF/F 7666A-2
Serial number CH25337
@Cody Stallings is our prop guru. He'll know.
The Hartzell 3-blade on my C doesn't need any of that stuff. I thought it was only a particular McCauley hub, but I'm not sure.
I believe you do need a eddy current inspection as your S/n does not have a suffix "B".
You should be able to find an Ad online and more details in it.
Actually your propeller hub is Non-Suffix.
Its actually supposed to have a one-time tear down inspection performance. At that time the Hub Serial number will have an E stamped.
After that the 100 ECI inspections start.
