30 minutes ago, LANCECASPER said:
More food for thought:
Thanks for that. I look forward to having a complete new panel...feels like its ages away....more time to try and save up some money :)
I did notice that there was no annunciator panel in that F model...wondering if I can get rid of mine in the J with the new panel?
You won't be able to get rid of the annunciator, per se, but you CAN relocate it where structurally-permissible to make more room in the radio stack.
Removal entirely is based on your installer.  A field approval is likely not to go through, but your installer can, as @ArtVandelay noted, make it a minor mod.
30 minutes ago, Mscheuer said:
In case you would want to update your panel drawing, here is a JPEG of our PMA8000G
Product Photos
Done and done...all to scale :)
Man, theres a lot to consider..............
More changes will be coming no doubt :)
Just now, StevenL757 said:
You won't be able to get rid of it, per se, but you CAN relocate it where structurally-permissible.
Is it possible to get rid of the cautions and warnings that are not used anymore...such as vacuum?
Yes.  You would either...
  • Leave the physical annunciator panel overlay as-is, and simply remove the bulb(s) that no longer are providing any function, or:
  • Fill all annunciator light bulb sockets with a working bulb, and create a new overlay with only the annunciations applicable to your aircraft's new equipment and configuration.
I've done the latter option for a couple of people here (not including my own annunciator panel - visible in the earlier panel pic).  It allows you to see every light in the annunciator panel...whether it serves a purpose, or whether it has a "hyphen" line through it - indicating no functionality, but reserved for future use.  This option also provides for a much cleaner panel appearance.
Sure you can. Minor mod, the annunciator doesn’t do anything fancy.
Those "Gear Down" and "Gear Unsafe" lights...those were a mod?
Just now, ArtVandelay said:
Yes, noticed no annunciator.
Wasn't sure if the panel might have been in a different area that I couldn't see. I'll reach out to my avionics guy and see what he thinks. Aside from the gear mod...is there any others related to the annunciator that I should be thinking of?
