Fly Boomer Posted December 29, 2021 Author Report Posted December 29, 2021 The first picture at the top of this thread is from @BrianW and, while it is showing a 3-inch extension, it also clearly shows the two sets of holes in the rudder pedal casting. 1 Quote
Fly Boomer Posted December 29, 2021 Author Report Posted December 29, 2021 Someone earlier in this thread says it is pretty easy to remove them... Quote
PT20J Posted December 29, 2021 Report Posted December 29, 2021 You guys are making this two complicated Mooney had two kits as shown in the drawing I posted: 1.5” which is just a short linkage, and 3” which has the U shaped bracket. When Mooney incorporated the 1.5” extension it was by merely installing the 1.5” kit during production. @Ragsf15e You can easily tell if you have the 3” kit because it requires a couple of screws through the rudder pedal easily visible between the upper and lower “treads.” Skip 1 1 Quote
Fly Boomer Posted December 29, 2021 Author Report Posted December 29, 2021 Thanks @PT20J for confirming what we somewhat laboriously concluded. Maybe this thread, and your succinct summary, will save someone else from struggling with this. 2 Quote
Ragsf15e Posted December 29, 2021 Report Posted December 29, 2021 52 minutes ago, Igor_U said: yes, that's correct. In originals install pedal would be mounted to the other set of holes (nut visible on bottom left ) and brake rod end on the pedal hole you circled. Now, that you mentioned it, I wonder what I have in my 67F. I spent some time under the panel but never paid any attention. I am 6'6.5" and always move to the seat to the last stop on the seat rail and in flight I slide the seat to the pin stop for more legroom. Sunny and 29 deg. in SEA - too cold to spend any time in my hangar these days... ha! Weak! It’s 16 degrees here in Spokane and I’m going to the airport to look at my rudder pedals! 2 Quote
Ragsf15e Posted December 29, 2021 Report Posted December 29, 2021 Dang, I don’t have extensions. I would have loved the extra inch, but I guess I’m glad I didn’t suffer unnecessarily for the last 7 years. I use the last seat hole or slide back in flight. Here’s a picture for future reference… 1 Quote
carusoam Posted December 29, 2021 Report Posted December 29, 2021 Summary…. 1) no extension… 2) 1.5” extension… 3) 3” extension… Now everyone can go see and know what they have…. Note: the third pic doesn’t show the brake hardware (clevis and Rod) installed… Those pics gives a good idea for where to put your feet, when flying vs. taxiing…. PP thoughts only, -a- 1 Quote
FlyboyKC Posted December 30, 2021 Report Posted December 30, 2021 If anyone want to get rid of a pair please let me know. Thanks Quote
Ragsf15e Posted December 30, 2021 Report Posted December 30, 2021 12 minutes ago, FlyboyKC said: If anyone want to get rid of a pair please let me know. Thanks It looks like a small piece of bent steel with 2 holes for the 1.5” extension. Then you shift the pedals to the back hole and use the piece of metal for the brake connection. If it can’t be procured, you might think about owner produced? The 3” version seems like a little more work. Quote
Planegary Posted December 30, 2021 Report Posted December 30, 2021 (edited) I got the plans from the archives here and took them to a cnc machine and in short order I had 3 inch extensions that my mechanic installed at annual Edited December 30, 2021 by Planegary Autocorrect error 1 Quote
willerjim273 Posted June 21, 2022 Report Posted June 21, 2022 This one has been all over the place! I figure we need get to a real question of "what is trying to be accomplished?" With that, how many of us are expecting to have full control - without getting brakes involved - to do both without taking feet of the pedals? It seems as though you have to decide if you want to control both at same time or "stab" at the bottom "rudder" then move up to the brakes as needed. on landing. I have to admit it would be nice to have both. How many of us are "riding" the rudder without moving feet on landings? I have an 80' K with the rudder pedal extensions - I cannot figure it out. Part # is T 20 115 -003 REV B, 24043887 03 /07/201J M43. Also, can someone please send me info on adjusting the length of the brake actuation rod? Do I have to pull a panel below or push the boot down? Thanks!! Quote
willerjim273 Posted June 21, 2022 Report Posted June 21, 2022 Yes this topic has been all over the place. I have the 3 in rudder extensions. they seem to be adjusted right on the verge of actuating the brakes. I don't think there is any way to adjust in the extension itself. To order to adjust the brake rod, can someone please tell me if that is accessible from the cockpit or pull a panel from below? I would imagine there is a threaded shaft with a jam nut on it somewhere. Kind of a tight space so if I simply push the fabric boot way down is it there?. Thanks very much Recovering from surgery is my excuse.. Tks Quote
PT20J Posted June 22, 2022 Report Posted June 22, 2022 (edited) When I installed 3" extensions, I had to adjust the brake master cylinders in order to tip the pedals forward so as to not accidentally apply the brakes. Here are the details from an old post… The service manual doesn't mention this adjustment. I did it on my '94 J today. A bit of a PITA -- had to remove the cowling to get to the fasteners on the front of the left exhaust cavity and also had to remove the left nose gear door since the piano hinge is on top of the inboard side of the cavity, and, of course, someone had cammed out one of the screws, so I had to drill and extract it. But, after that the brake cylinders are easily accessed. At first I thought I'd have to remove the clevis pins to rotate the threaded rod end, but since the brake cylinder shaft is round, all I had to do was adjust the jam nut which rotates the shaft while the clevis pin keeps the threaded rod end from rotating thus allowing the length of the rod to be adjusted. There are flats on the brake cylinder shaft just behind the nut that, after compressing the spring, you can put an open-end wrench on to keep the shaft from turning while you check the torque on the jam nut when done. Skip Edited June 22, 2022 by PT20J Updated with details from previous post. Quote
