squeaky.stow Posted October 16, 2021 Report Share Posted October 16, 2021 Just had an oil change and turbo inspection. The day prior, I had noticed more oil on the nose gear than usual, so we did a thorough cleaning and leak check. More oil on the nose gear. Uh-oh! There are two check valves for the turbo (feed and return) that are clamped under the oil sump with P clamps that have a rubber grommet around them. The grommet on the feed line had worn through on the inside and it was not possible to detect this visually without removing the clamps. I am guessing this has been wearing for a long time and finally chafed a hole in the check valve. Lucky for me it just started leaking noticeably shortly before I booked the turbo inspection for a separate issue. Anyone have one of these sitting around? Mooney Part number 642211. Dukes part number 1240-00-1. Quote Link to comment Share on other sites More sharing options...
hubcap Posted October 16, 2021 Report Share Posted October 16, 2021 I had to have one replaced on my M20K earlier this year. The mechanic ordered it from a parts place down in Alabama. I do not remember what the name of the dealer was, but I do remember the part was ~$1,300. Quote Link to comment Share on other sites More sharing options...
N201MKTurbo Posted October 16, 2021 Report Share Posted October 16, 2021 I have one that’s in better shape than that one. I replaced both when I rebuilt my engine. Ill be at the hangar tomorrow and will send you a pic. Quote Link to comment Share on other sites More sharing options...
carusoam Posted October 17, 2021 Report Share Posted October 17, 2021 I believe @tomgo2 may have spare parts for turbos like that… (Mooney turbo check valve leaking) Best regards, -a- Quote Link to comment Share on other sites More sharing options...
N201MKTurbo Posted October 17, 2021 Report Share Posted October 17, 2021 7 minutes ago, carusoam said: I believe @tomgo2 may have spare parts for turbos like that… (Mooney turbo check valve leaking) Best regards, -a- That’s where I got mine. They aren’t cheap, but not $1300, more like $450. The one I have will get him to TBO if he is looking for a quick fix. 1 Quote Link to comment Share on other sites More sharing options...
N201MKTurbo Posted October 17, 2021 Report Share Posted October 17, 2021 BTW, when I put in new ones, I wrapped the check valve with fire sleeve and clamped to the hose Instead of the valve. I’ll let you know how that turns out in 20 years. Quote Link to comment Share on other sites More sharing options...
squeaky.stow Posted October 17, 2021 Author Report Share Posted October 17, 2021 Thank you Rich. I would never have imagined a valve could be worn down like that by a clamp. I will definitely be clamping to the hose when it goes back in. Mark Quote Link to comment Share on other sites More sharing options...
carusoam Posted October 17, 2021 Report Share Posted October 17, 2021 6 minutes ago, squeaky.stow said: . I would never have imagined a valve could be worn down like that by a clamp. Mark Check the materials of construction… If that is an aluminum part… And you used a steel or chromed clamp….. in contact with the part… that surely explains the damage… If the clamp had a nice rubber contact surface… looks like the rubber got away… Mooneys have many aluminum lines that are at risk when something harder rubs against them… including nylon wire tires… Pp thoughts only, not mechanic… Best regards, -a- Quote Link to comment Share on other sites More sharing options...
kortopates Posted October 17, 2021 Report Share Posted October 17, 2021 Thank you Rich. I would never have imagined a valve could be worn down like that by a clamp. I will definitely be clamping to the hose when it goes back in. MarkFor TCM installations, TCM requires their own TCM clamps and i recall reading somewhere that standard clamp’s weren’t permitted for this reason - such as a service letter or bulletin or maybe it’s in M-0 now. But the TCM clamps can be ordered via Spruce and i recall yellow in color so as not be mistaken for the common black ones which have been know to cause that kind of damage.Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
N201MKTurbo Posted October 17, 2021 Report Share Posted October 17, 2021 4 minutes ago, kortopates said: For TCM installations, TCM requires their own TCM clamps and i recall reading somewhere that standard clamp’s weren’t permitted for this reason - such as a service letter or bulletin or maybe it’s in M-0 now. But the TCM clamps can be ordered via Spruce and i recall yellow in color so as not be mistaken for the common black ones which have been know to cause that kind of damage. Sent from my iPhone using Tapatalk Good to know, the M20Turbos STC has no mention of that, even though they are the same valves. 1 Quote Link to comment Share on other sites More sharing options...
kortopates Posted October 17, 2021 Report Share Posted October 17, 2021 Good to know, the M20Turbos STC has no mention of that, even though they are the same valves.interesting since i didn’t know the M2OTurbos STC used the same check valves - but certainly makes sense. thanks Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
M20F-1968 Posted October 17, 2021 Report Share Posted October 17, 2021 I had my check valves rebuild ten years ago by the manufacturer (I do not recall their name just now - it may have been Dukes). As I recall, the rebuild price was about $250.00. John Breda Quote Link to comment Share on other sites More sharing options...
squeaky.stow Posted October 17, 2021 Author Report Share Posted October 17, 2021 8 hours ago, kortopates said: But the TCM clamps can be ordered via Spruce and i recall yellow in color so as not be mistaken for the common black ones which have been know to cause that kind of damage. Good to know. Mine were yellow and I presume they have been there since the engine was overhauled. On close inspection it appears they were poorly installed, forcing some of the rubber off the clamp in a critical area. I will have my maintenance guy order the right ones from Spruce. Quote Link to comment Share on other sites More sharing options...
N201MKTurbo Posted October 17, 2021 Report Share Posted October 17, 2021 8 hours ago, kortopates said: interesting since i didn’t know the M2OTurbos STC used the same check valves - but certainly makes sense. thanks Sent from my iPhone using Tapatalk The turbo system on the M20Turbos is straight off of the 231. The turbo, check valves and scavenger pump are the same along with the fixed wastegate. It is weird putting Continental parts on a Lycoming. 1 Quote Link to comment Share on other sites More sharing options...
N201MKTurbo Posted October 17, 2021 Report Share Posted October 17, 2021 20 hours ago, squeaky.stow said: Just had an oil change and turbo inspection. The day prior, I had noticed more oil on the nose gear than usual, so we did a thorough cleaning and leak check. More oil on the nose gear. Uh-oh! There are two check valves for the turbo (feed and return) that are clamped under the oil sump with P clamps that have a rubber grommet around them. The grommet on the feed line had worn through on the inside and it was not possible to detect this visually without removing the clamps. I am guessing this has been wearing for a long time and finally chafed a hole in the check valve. Lucky for me it just started leaking noticeably shortly before I booked the turbo inspection for a separate issue. Anyone have one of these sitting around? Mooney Part number 642211. Dukes part number 1240-00-1. This is the oil feed side check valve I have. It looks a bit different than yours. Even though it will probably work. This is its worst side. Quote Link to comment Share on other sites More sharing options...
tomgo2 Posted October 17, 2021 Report Share Posted October 17, 2021 RAJAY has check valves if needed. There are two different types in stock; the "flapper door" style and the "spring loaded" type. Neither are PMA'd so we can provide specs of each to make your own determination and application. Search for RJ5315 and/or RJ5316. Tom 1 Quote Link to comment Share on other sites More sharing options...
squeaky.stow Posted October 19, 2021 Author Report Share Posted October 19, 2021 On 10/17/2021 at 10:53 AM, N201MKTurbo said: This is the oil feed side check valve I have. It looks a bit different than yours. Even though it will probably work. This is its worst side. I am guessing there is no part number visible on it? It certainly looks similar. Quote Link to comment Share on other sites More sharing options...
squeaky.stow Posted October 19, 2021 Author Report Share Posted October 19, 2021 On 10/17/2021 at 1:25 PM, tomgo2 said: RAJAY has check valves if needed. There are two different types in stock; the "flapper door" style and the "spring loaded" type. Neither are PMA'd so we can provide specs of each to make your own determination and application. Search for RJ5315 and/or RJ5316. Tom Thanks Tom, I will pass this info on to my maintenance provider. Quote Link to comment Share on other sites More sharing options...
N201MKTurbo Posted October 19, 2021 Report Share Posted October 19, 2021 1 hour ago, squeaky.stow said: I am guessing there is no part number visible on it? It certainly looks similar. It is exactly the same as RAJAY is selling. I can get you apart number if you like. Quote Link to comment Share on other sites More sharing options...
squeaky.stow Posted October 20, 2021 Author Report Share Posted October 20, 2021 For all of you that offered your help and advice, thanks so much. Please standby for further. My maintenance guy was well ahead of me and appears to have found a local source. I should know in a day or so. 1 Quote Link to comment Share on other sites More sharing options...
Fly Boomer Posted October 19, 2022 Report Share Posted October 19, 2022 On 10/16/2021 at 4:47 PM, hubcap said: I had to have one replaced on my M20K earlier this year. The mechanic ordered it from a parts place down in Alabama. I do not remember what the name of the dealer was, but I do remember the part was ~$1,300. Might have been directly from Continental. Was this CSB the reason for the replacement? http://www.tcmlink.com/pdf2/CSB95-1A.pdf Quote Link to comment Share on other sites More sharing options...
hubcap Posted October 20, 2022 Report Share Posted October 20, 2022 3 hours ago, Fly Boomer said: Might have been directly from Continental. Was this CSB the reason for the replacement? http://www.tcmlink.com/pdf2/CSB95-1A.pdf No, mine had to be replaced because it started leaking. Quote Link to comment Share on other sites More sharing options...
LANCECASPER Posted October 20, 2022 Report Share Posted October 20, 2022 On 10/16/2021 at 1:03 PM, squeaky.stow said: Just had an oil change and turbo inspection. The day prior, I had noticed more oil on the nose gear than usual, so we did a thorough cleaning and leak check. More oil on the nose gear. Uh-oh! There are two check valves for the turbo (feed and return) that are clamped under the oil sump with P clamps that have a rubber grommet around them. The grommet on the feed line had worn through on the inside and it was not possible to detect this visually without removing the clamps. I am guessing this has been wearing for a long time and finally chafed a hole in the check valve. Lucky for me it just started leaking noticeably shortly before I booked the turbo inspection for a separate issue. Anyone have one of these sitting around? Mooney Part number 642211. Dukes part number 1240-00-1. That's a TCM part number not Mooney. https://www.airpowerinc.com/642211 https://www.aircraftspruce.com/catalog/eppages/continentalnewvalves_07-06967.php At those prices I would definitely be buying from @tomgo2 Quote Link to comment Share on other sites More sharing options...
M20F-1968 Posted December 5, 2022 Report Share Posted December 5, 2022 On 10/16/2021 at 7:37 PM, N201MKTurbo said: I have one that’s in better shape than that one. I replaced both when I rebuilt my engine. Ill be at the hangar tomorrow and will send you a pic. Do you still have your check valves? John Breda Quote Link to comment Share on other sites More sharing options...
N201MKTurbo Posted December 5, 2022 Report Share Posted December 5, 2022 I do, but the return check valve has a broken spring. Quote Link to comment Share on other sites More sharing options...
