OK here is a crazy question..... I am a new owner of a vintage 1966 M20F, but the more I look for interior parts, etc. I am having a hard time with what the FAA registration says and my serial number. Any help, mainly with serial number is appreciated!
FAA Data:
N3538X
1966 Mooney M20F
Serial Number 670075
As I look at Vantage Pane Plastics, the dash panel shows M20C,D but mine is the stretch model. Any thoughts???
I own a 67 M20F.....670093!  Must have rolled off the line just a bit after yours did.
The FAA considers mine a '67 and it matches the data plate as well.
Great airplanes!  Enjoy yours!
15 minutes ago, PeteMc said:
Wow a new factoid.  I never knew the older models started with the year they were manufactured.
Any idea when they stopped that?
Not all serial numbers start with the production year.... I believe the year the FAA uses is the year the Airworthiness Certificate was issued, so if a manufacturer is building a 1968 and it’s late 67’ it becomes a 67 sane is true on the other end of year... when needing parts I always use what the manufacturer says it is... no issues so far
Find the serial number.  on my A model it is an embossed metal tag of the aft face of the spar.  Don't know about the metal wing AC.
Edited by mike20papa
dd
Mine is 670049.  FAA calls it a '66 because the airworthiness date is 9/22/66, but it is definitely a '67 model.
Your airworthiness date is 10/11/66, so just a few days younger than mine, but also, most definitely, a '67 model.
@Sheriff23 Your airworthiness date is 11/17/66, so the FAA registration says it is a '66.  Here's a link to it https://flightaware.com/resources/registration/N9516M
Same with my E. The S/N and the options said it was a '66, but the FAA insisted on it being a '65 because airworthiness was granted October '65.
My E from 1964 doesn’t start that way FYI.  It’s just the serial number in the hundreds.
My E is back near the tail kinda under the empennage on pilot side on the main fuselage.  Where every plane pretty much has it...
It changed some time in 1967 by the looks of it
These days yes, but there's quite a few who have it in fun locations as well.
Serialized manufacturing wasn’t a very common practice back in the day... leading to funky numbers, and odd locations to place the tag…
How to do it…. What you can get out of it.. changed a lot after the computer became widely used…
Early on… all Mooneys got a serial number that basically told you nothing about the plane… and more about  how many Mooneys were built overall…
Somewhere around when the M20F was first being manufactured… things started to get serious… the SN began with a number to represent the model…
Each model had a few development mules… so they got early serial numbers… but their date of air worthiness technically occurred much later…
Soooo… every year for a while… there were planes built in one year… that became AW the following year… and what standard they were built to was still different from the build date and AW date…
If you are fortunate to have the first airframe log for your Mooney…  in the early pages you will find things like paint codes used… what days the AW flights occurred… and who signed the AW stamp…
My first Mooney was a 65 M20C, it’s AW flights occurred around August, and was signed off by the engineer, Bill Wheat…
30 years had past… I called the factory with a question… I had just bought the plane…. I needed a POH…. I spoke with a guy in the parts department…. I spoke with the same Bill Wheat that had signed off my AW in my airframe log….  :)
Today…. From the serial number… you will know exactly what plane it is referencing… and computerized records will be able to tell you the serial number of the exhaust valves in the engine… (for the more modern birds)
We have come a long way…
PP thoughts only… not a manufacturing engineer…
When sales were slow, we wouldn’t DMIR an aircraft, which is what trips the Airworthiness Certificate until the aircraft sold, among other things, it gave the new owner a full year before the annual was due, and sometimes the delay made it be Certified in the next year than what it was manufactured.
It wasn’t uncommon for an airplane with a larger serial number to be last years airplane, when one actually manufactured before it to be this years airplane, because one was built to order and the other one wasn’t.
Edited by A64Pilot
