1989 J MSE has a stall warning going off continuously from the initial turn-on of the battery switch.  Moving the stall vane seems to have no effect.  Cycled CB on and off, still no luck.  Ideas?
Grab the sonolert and pull down on it and see if it quits. If it touches the roof skin it will go off.
What is the sonolert?
It is the thing on the ceiling that makes the noise.
All that is assuming the 98 still has sonalerts on the ceiling.
Pull the stall horn breaker AND the gear horn breaker to stop it.  It is crazy but that is how the wiring is done.  After that you likely need a new microswitch in the stall warning vane.  They are a standard part available from Mouser for less than $10.  Alternatively a new part from the manufacturer is around a grand.
Use the forum search function.  This has all been discussed before.  You will find discussion and applicable part numbers.
In the early 90s...
Mooney went with tones instead of Sonalert buzzers in some models...
The ‘94 O has tones...
+1 for finding the pics of the stall switch...  somebody posted all the details to rebuild one...  and there is a full follow-up on if that is a legal fix or not...
+1 for Rich’s explanation on how the Sonalert scan set themselves off... this is probably true for both the buzzer and the tones...
Many thanks to Moosebreath, carusoam and N201MKTurbo for your help.  I did as you suggested with the CBs, that's how I decided it was stall warning over gear warning. Now on to the search function....thanks again.
Dooley,
Start with this thread... it is the most recent...   there may be others...
Later M20Js have a tone generator for the gear and stall warning that drives an overhead speaker rather than a sonalert. I’d start at the stall warning vane. It’s position is adjustable to set activation speed so mark it first.
Skip
Skip
To my knowledge all Mooneys came with a different sonalert for gear vs stall. The gear one is the tall one that makes an intermittent beep. It should be distinct. But I've flown in a lot of customer's Mooneys where the gear warning was bad and just made a steady tone. In that case the sonalert should be replaced.
-Robert
-Robert
1553650015_Screenshot2021-05-18at10_49_21AM.thumb.png.d308969c34781d656e423628e3451a2b.png
The stall vane on the wing provides a ground to activate the horn.  A failed switch or a wire shorted to ground, or as Rich mentions above the horn contacting the skin can cause the horn to sound continuously.
