It looks like those that were installed in the early J models. I have a pair, now covered with leather, in my F. The main difference between these early models and the those used later, is that the early J's had the same diameter control shaft as the vintage models. However, the hole where they bolt onto the control shaft differ by 90 deg between the vintage models and the J's. IIRC, the thick control shaft was introduced around '79 - '80.
This is what is on my F.  I'm not sure what model J they came from.  They have the heavier shaft.  They don't have the sharp angle like yours does.  It looks like the ones you have would lower your hands a couple of inches.
