hnorber Posted August 14, 2020 Report Posted August 14, 2020 Hi All: The rubber bracket that holds my exhaust pipe in place under the cowling is mostly cracked. Does anyone have a part number or explanation of where I can find a replacement part? I think the current one was fashioned from an old tire by my mechanic. Would also be grateful if anyone has a part number for the tail strobe for my plane. Shop quoted me about $300 - would hope that I can find for less. This is for a 1991 M20J (Really an MSE). Thnx
ArtVandelay Posted August 14, 2020 Report Posted August 14, 2020 If you going to spend $300, upgrade it to a LED for a little more.My muffler hangar is an owner produced part from a tire as it commonly is.
buddy Posted August 14, 2020 Report Posted August 14, 2020 I believe I bought a universal tail pipe hanger from an auto parts store and cut the rubber out from in between the metal brackets.
N201MKTurbo Posted August 14, 2020 Report Posted August 14, 2020 A few layers of reinforced baffle seal works well if you don’t like tires, Most hangars I visit have a stack of old airplane tires somewhere, so they are aircraft parts.... Make sure you cut the part of the side wall that says FAA-PMA on it. Who could argue with that? 1 1
carusoam Posted August 15, 2020 Report Posted August 15, 2020 There is a few threads around here regarding pics of peoples favorite tire art that had been cut for the job... A flying foot from a GoodYear... is pretty fancy... GoodYear has a blimp... that’s aviation.... The transitive property of air worthiness... For new style Whelen LED strobes find @OSUAV8TER he is the MS lighting resource... Best regards, -a- An example of tire discussion, and there are a few threads....
Yetti Posted August 15, 2020 Report Posted August 15, 2020 New blade in a utility knife. Old airplane tire sidewall. Use hanger as template to drill holes in the rubber. Or is that hangar. carry on
hnorber Posted August 16, 2020 Author Report Posted August 16, 2020 Thanks, everyone for the helpful replies!
Bob - S50 Posted August 16, 2020 Report Posted August 16, 2020 I was looking for the bracket and rubber piece about a month ago and found them at this MSC: 11 - D.L.K. Aviation Address 2601 Cessna Lane Kennesaw, GEORGIA 30144 United States Phone: 770.427.4954 Fax: 770.428.6180 Website: dlkaviation.com
