Niko182 Posted July 22, 2021 Report Posted July 22, 2021 34 minutes ago, Skates97 said: I don't think you need the YD in a short body The only people that need the YD are the ones that have flown with a garmin yaw damper before. If you've never flown with one youll be fine, because you don't know what you're missing out on. Just make sure you never fly one with a YD. 1
carusoam Posted July 22, 2021 Report Posted July 22, 2021 8 minutes ago, Niko182 said: The only people that need the YD are the ones that have flown with a garmin yaw damper before. If you've never flown with one youll be fine, because you don't know what you're missing out on. Just make sure you never fly one with a YD. Kinda like that 310hp…. Or that 180hp, when your prior experience was all 108hp… Best regards, -a-
ArtVandelay Posted July 22, 2021 Report Posted July 22, 2021 The only people that need the YD are the ones that fly in turbulence.FIFYBonanza V tails owners love it, they yaw at the slightest bump.
FlySafe Posted July 22, 2021 Report Posted July 22, 2021 On 7/19/2021 at 12:02 AM, Skates97 said: Looks like my memory wasn't very good, mine aren't any different than yours. Richard, thanks for checking! The installer fashioned a bracket to hold the buttons and i think it will work well once painted black and labeled. Had to forgo the nice optional trim switch on yoke for the standard Garmin trim toggle
FlySafe Posted July 22, 2021 Report Posted July 22, 2021 sorry about the unusual attitude, maybe someone can teach me how to rotate a figure thanks k
Buckeyechuck Posted July 22, 2021 Report Posted July 22, 2021 Thanks I will definitely check on those options for cost. It is a ‘62 after all. I’m already way beyond ever getting even a chunk of my investment back and still need a paint job.
Hank Posted July 22, 2021 Report Posted July 22, 2021 2 hours ago, FlySafe said: Richard, thanks for checking! The installer fashioned a bracket to hold the buttons and i think it will work well once painted black and labeled. Had to forgo the nice optional trim switch on yoke for the standard Garmin trim toggle That's right where my Push-to-Talk button is mounted . . . .
Skates97 Posted July 22, 2021 Report Posted July 22, 2021 2 hours ago, FlySafe said: Richard, thanks for checking! The installer fashioned a bracket to hold the buttons and i think it will work well once painted black and labeled. Had to forgo the nice optional trim switch on yoke for the standard Garmin trim toggle Interesting that it is just a toggle and not a split switch. 1 hour ago, Buckeyechuck said: Thanks I will definitely check on those options for cost. It is a ‘62 after all. I’m already way beyond ever getting even a chunk of my investment back and still need a paint job. From day one I never planned to get any of my investment back in dollars, but in enjoyment it has paid me back ten-fold.
kpaul Posted July 22, 2021 Report Posted July 22, 2021 15 hours ago, carusoam said: KP, I think Siri altered your spelling… would wouldn’t… -a- Nope, in this case I meant would...I would recommend getting the electric trim. I personally hate the little trim wheel between the seats. I also like to keep my hands on the yoke and throttle during critical phases. 1
Seymour Posted July 23, 2021 Report Posted July 23, 2021 @kpaul, does the right seat have access to the electric trim? (assuming arm length within 2 standard deviations of the average mooney driver, of course).
jamesm Posted July 24, 2021 Report Posted July 24, 2021 How do you remove the Garmin AP (bottom switch) I have removed the silver collar but the switch won't budge. I have similar setup except I put a bushing hole for the wing leveler disengage button and mounted my PTT switch. I didn't want damage it. I want to try out a different arrangement. Thanks in advance, James '67C
FlySafe Posted July 24, 2021 Report Posted July 24, 2021 James, not sure how the PC button on yoke is removed but believe i have heard others mention it is held in place simply via an o-ring but I’m not an AP. here is a few panel pics of the cleaned-up panel arrangement with the gfc500 installed.
jamesm Posted July 24, 2021 Report Posted July 24, 2021 (edited) I was referring to removal of the Garmin AP Disconnect red button see below. The silver collar backs off easy but doesn't come off the rest of button assembly didn't want to move. I have already removed the PC wing lever button that is where my PTT is located. James '67C Edited July 25, 2021 by jamesm clarification
Ragsf15e Posted July 24, 2021 Report Posted July 24, 2021 On 7/22/2021 at 8:28 AM, Buckeyechuck said: Thanks I will definitely check on those options for cost. It is a ‘62 after all. I’m already way beyond ever getting even a chunk of my investment back and still need a paint job. Ha! Calling it an “investment” is your first mistake! 1
FlySafe Posted July 24, 2021 Report Posted July 24, 2021 3 hours ago, jamesm said: I was referring to removal of the Garmin AP Disconnect red button see below. The silver collar came off easy but the rest of button assembly didn't want to move. I have already removed the PC wing lever button that is where my PTT is located. James '67C Sorry misunderstood, sure someone here or your Garmin installer can provide some guidance, good luck
Buckeyechuck Posted July 25, 2021 Report Posted July 25, 2021 2 hours ago, Ragsf15e said: Ha! Calling it an “investment” is your first mistake! Not an investment. A labor of love. 2
Hank Posted July 25, 2021 Report Posted July 25, 2021 1 hour ago, jamesm said: or expensive hobby Are any hobbies really inexpensive? Like when a friend of mine talked me into working with the Boy Scout troop, "it's only a half hour meeting each week."
Shiny moose Posted July 25, 2021 Report Posted July 25, 2021 7 hours ago, jamesm said: I was referring to removal of the Garmin AP Disconnect red button see below. The silver collar backs off easy but doesn't come off the rest of button assembly didn't want to move. I have already removed the PC wing lever button that is where my PTT is located. James '67C james, could you please show a picture of your PTT installing in the PC button hole. Also make and model of the switch and any other info you can share, thats next on my todo list. J
jamesm Posted July 25, 2021 Report Posted July 25, 2021 (edited) 43 minutes ago, Shiny moose said: james, could you please show a picture of your PTT installing in the PC button hole. Also make and model of the switch and any other info you can share, thats next on my todo list. J I had misspoken earlier the silver collar unscrews but that is as far as I can go. This silver collar doesn't complete come off , if it did I could back out the AP switch from the mounting (Ram horn shaped ) sorry picture are sort of blurry I have to get better picture next time. Edited July 25, 2021 by jamesm
jamesm Posted July 25, 2021 Report Posted July 25, 2021 (edited) I figured it out the little red button is thread once unthread it the silver collar came off and the switch dropped out the back. the picture is crummy. Thanks Edited July 25, 2021 by jamesm
Shiny moose Posted July 25, 2021 Report Posted July 25, 2021 Dont see the pictures, not sure its me or you, can we try again for pictures 1
carusoam Posted July 27, 2021 Report Posted July 27, 2021 On 7/25/2021 at 3:43 AM, jamesm said: I figured it out the little red button is thread once unthread it the silver collar came off and the switch dropped out the back. the picture is crummy. Thanks James the pic didn’t show at all… Great detail on the switch construction! Best regards, -a-
jamesm Posted July 27, 2021 Report Posted July 27, 2021 Oops. Let me try again. The picture is still crummy. 1
kpaul Posted July 29, 2021 Report Posted July 29, 2021 On 7/22/2021 at 10:21 PM, Seymour said: @kpaul, does the right seat have access to the electric trim? (assuming arm length within 2 standard deviations of the average mooney driver, of course). My electric trim is only on the pilots yoke. I don't know if dual trim switches in an option.
