RobertGary1 Posted May 22, 2020 Report Posted May 22, 2020 Just did my Hartzell EDI inspection up at Lincoln airport. $150. Otherwise I'd been quoted $500. This place does industrial weld inspections but they have their FAA repair station license to do these inspections. They are not A&Ps (only certified for prop inspections) so you need to find a way to R&R the spinner. http://www.ctcservicesinc.com/ -Robert 1 Quote
MooneyMitch Posted May 22, 2020 Report Posted May 22, 2020 1 minute ago, RobertGary1 said: Just did my Hartzell EDI inspection up at Lincoln airport. $150. Otherwise I'd been quoted $500. This place does industrial weld inspections but they have their FAA repair station license to do these inspections. They are not A&Ps (only certified for prop inspections) so you need to find a way to R&R the spinner. http://www.ctcservicesinc.com/ -Robert Thank you Robert. Good to know in case Golden State is no longer available. Quote
bonal Posted May 23, 2020 Report Posted May 23, 2020 Yes I used CTC on my last hub inspection and mentioned them on a couple other threads on the subject . There tech did the most thorough inspection of any I have used. Ramp elves handled the RR on the spinner. 1 Quote
Hank Posted May 23, 2020 Report Posted May 23, 2020 It's a lot of screws, but I can remove the spinner from my 3-blade Hartzell in about 15 minutes (if some clown hasn't used his cordless drill to run in the screws!). 1 Quote
carusoam Posted May 23, 2020 Report Posted May 23, 2020 Iirc.... nylon washers under the stainless screw heads.... keep things from sticking too hard...(?) Best regards, -a- Quote
Hank Posted May 23, 2020 Report Posted May 23, 2020 11 hours ago, carusoam said: Iirc.... nylon washers under the stainless screw heads.... keep things from sticking too hard...(?) Best regards, -a- Done on all inspection panels and spinner. But my first annual where I had almost no participation (about annual #8 or #9), I think they used an impact driver to put the spinner back on. Took me 45 minutes, pushing into each screw with both legs and my back, to get the last dozen spinner screws out . . . . 1 Quote
MIm20c Posted May 23, 2020 Report Posted May 23, 2020 (edited) I use a Bosch compact model with torque settings. Works great, absolutely perfect amount of torque every time. Bad mechanics are as common as bad pilots...don’t blame the tool. Edited May 23, 2020 by MIm20c 1 Quote
