khedrei Posted April 27, 2020 Report Posted April 27, 2020 ** UPDATED Aug 19th 2020. Prices reduced. I would love to clear this stuff out. Happy to make a deal for bulk. Spend $1000 and I will throw in $150 worth of extra stuff for free and pay shipping to Canada or USA (Offer not eligible on certain items noted below). NEW ITEMS ADDED and some non Mooney items** I have serial numbers for. EVERYTHING is functional/working as intended unless otherwise noted beside the item. If you are interested in an item and the part number doesn’t seem to match please inquire. I have priced things the best I could (25-50% lower on average) based on Texas Air Salvage as well as Ebay but some of them could be out of whack. Don’t hold this against me. If you are interested, simply leave me an offer and we can work something out. I live in Canada so Interac Etransfer from a Canadian bank is great, otherwise PayPal is fine. Prices are USD. Buyer pays actual shipping costs through whatever method is best for both of us, I will not gouge anyone on shipping. Items I have shipped (that fit in a shoebox sized box) generally arrive in 1-2 weeks and cost around 15-20 USD. I offer no warrenty aside from the item working as advertised so I will issue a refund for anything DOA but no time period after so please be prepared to test or install in a reasonable amount of time. You can PM me here, but for a faster response you can email me at kevinhedrei@hotmail.com or call or text 905-399-1588. If I don't respond I'm probably flying. -JPI EDM 700 Engine monitor P/N EGT-7014C. Harness included and is in great shape. 5CHT probes (not sure why I’m missing one). 6 EGT probes, TIT probe, Oil temp probe, CDT probe $700 MOONEY SPECIFIC (ish) STUFF -Mooney OEM instrument cluster. Model 6247-00066 P/N 640281-513 $300 -Mooney OEM Rheostat Dimmers P/N JS1N055P251MA w/plug and harness. (**Edit I have the knob caps) $30 -4x Mooney OEM fuel senders. Have serial/part #’s. (worked well but dirty with sealant) $300 FOR ALL -2x Power supply for wing tip strobes P/N 701295-3A $40 EACH -Nav light housings and lenses (1 for each side) + Bulbs $30 EACH -2x Klixon Switch Breakers. P/N 20TC2-BG-5 (5 amp) P/N 20TC2-BG-10 (10 amp) Covers are for elevator trim & Prop Deice but the prop deice cover came from the strobes. Ordered a new switch and changed the cover because the new strobes needed 15 amps. $50 EACH AVIONICS -King KT76A Transponder w/tray P/N 066-1062-00 $100 -1x King KR87 ADF TSO w/tray P/N 066-1072-00 (display occasionally dims/flickers when cold but fine once warmed up) $200 -King KI227 ADF indicator P/N 066-3063 $200 -King KMA24 Audio Panel w/tray *edit I found wiring harness $200 -2x DM N170-2 Antenna (hooked to transponder and DME I believe) $50 EACH -Telex Intercom control. PC4 Cat# 70650-000 $80 -Bendix Magneto Ignition Switch w/4 keys P/N 0-357210-9 $150 -Altitude Encoder/Digitizer Model# SSD120-25 $100 -Tachometer RPM 2700 Redline B&D P/N 0506-005 $200 -Narco stand alone DME $150 -Narco Audio panel (worked but was getting some static and interfeerence in a flight school plane not terrible, but annoying) $FREE you pay shipping. ODDS & ENDS -DM 121.5 Mhz ELT (Battery due) $40 -Mitchell Aircraft Products Oil PSI sender P/N PS-211-9040 $30 NEW or NEAR NEW stuff - This stuff is not mine so not eligible for the discount offer I made above but feel free to make an offer. -Ameri-King Corb Altitude Encoder P/N AD350 (BRAND NEW in box) $200 -Narco Avionics Nav 121 TSO VOR receiver indicator all in one. (Excellent condition) $500 -Terra Corp voltage converter Model# C28-5 $60 each -2x Welden Tool Co. Fuel pump. P/N C8100-F (BRAND NEW) $750 -United Instruments Altimeter P/N C661071-0101 (Out of a Cessna I believe) $500 -MGL Avionics VFH Comm Model V10 FCCID WSJV10 (Like new with Harness) $500 Non Mooney stuff - This stuff is not mine so not eligible for the discount offer I made above but feel free to make an offer. -Seats which were custom made for a Pitts. BRAND NEW perfect condition. Belong to a friend. I think he decided the colour wasn't good and made new ones. These are honestly perfect and never been installed. He paid well over $2000 CAD to make them. They come with booster cusions for under the finished seat and velcro for attachement. I have more pictures and can get exact measurements. Asking $1400 USD -7 point seat belt set. Blue and red in colour. All hardware and webbing in great shape. He doesn't like the colour. More pics available on request. Asking $150 USD -2 Brand new brake discs that fit a Pitts. Pics and part numbers available on request. Offer? -2x Cleveland Hub, Bearing, Brake rotor COMPLETE assembly TSO Model 40-96E (BRAND NEW these were bought for a Lancair IVP I believe but you must do your due diligence and verify. They were $4000 each). Asking $2500 each. -B+C 60A Alternator (experimental) P/N BC462-H w/28V regulator included. (BRAND NEW IN BOX WITH RECEIPT and B&C Paperwork) $450 -Harzell 2 blade prop from Piper Malibu. Good condition with paperwork. BHC - CZYF - 1BF. (I don't know much about model numbers on these but I have pictures and pictures of paperwork and can get all the info you need. If you are interested I can put you in touch with the current owner. -Hartzell 2 Blade Aerobatic prop from a Pitts. Good condition as well. Not sure on paperwork status. HC - CZY. Again, I can get whatever info you need. -3 axis Autopilot Removed from 1973 (<-I think) Cessna 182 P (<- I'm sure) model. Working when removed for upgrade. Edo air T+B indicator TSO P/N 52D75-14. Edo Roll servo P/N 1C363-1-397-R (the "397" is faded so could be wrong). Pitch servo Stec P/N 0107-P4. Trim Servo Stec P/N 0105-T10. Alt Controller Stec P/N 0117 "brain" Stec P/N 0110-2TF 2
charlesual Posted April 27, 2020 Report Posted April 27, 2020 Hi,I’m interested in the trim motor and relay. Do you have the control wheel trim switch?Thanks,Charlie Sent from my iPhone using Tapatalk
Hank Posted April 27, 2020 Report Posted April 27, 2020 I have a KY197 that works well as Com2, but my KN53 Nav2 is getting wonky. What were you using for Nav2?
khedrei Posted April 27, 2020 Author Report Posted April 27, 2020 53 minutes ago, charlesual said: Hi, I’m interested in the trim motor and relay. Do you have the control wheel trim switch? Thanks, Charlie Sent from my iPhone using Tapatalk Unfortunately I don't seem to have the switch. I really wish I did. We were on the outs when I left the shop at the end and I seem to be missing a few obvious things including the new trim switch from Garmin that we didn't end up using. If you want to email me with what you want I can send you some pictures of the trim motor, relay, and wiring that I have and you can verify that it will work for you. 30 minutes ago, Hank said: I have a KY197 that works well as Com2, but my KN53 Nav2 is getting wonky. What were you using for Nav2? The KNS 80 is what kept me legal with a Nav 2. I hardly ever used it but it worked fine aside from the occasional display issues when I did use it.
LANCECASPER Posted April 27, 2020 Report Posted April 27, 2020 Good Lord! Is there anything remaining in the airplane? Please show us what the new panel looks like! 3
khedrei Posted April 28, 2020 Author Report Posted April 28, 2020 2 hours ago, LANCECASPER said: Good Lord! Is there anything remaining in the airplane? Please show us what the new panel looks like! Not really. Pretty much everything went. I wanted to replace the rocker switches with something more modern but the installer wouldnt entertain signing off any kind of switch that didnt have paperwork no matter where it came from. I will snap a new pic tomorrow and post it. Quite an improvement for sure.
carusoam Posted April 28, 2020 Report Posted April 28, 2020 You might be able to get some really nice switches with all the proper paper work.... But they come with a bunch of CBs that need to be mounted as well... Consider it... if you can... nice lighted modern switches posted around here somewhere... Best regards, -a-
charlesual Posted April 28, 2020 Report Posted April 28, 2020 Kevin,I decided to waive off of the trim stuff. Thanks anyway. Sent from my iPhone using Tapatalk
khedrei Posted April 28, 2020 Author Report Posted April 28, 2020 4 hours ago, charlesual said: Kevin, I decided to waive off of the trim stuff. Thanks anyway. Sent from my iPhone using Tapatalk No problem Charlie, I put a request in with some guys at the shop to see if they can come about a yoke switch. Let me know if you change your mind. Tail strobe sold. Updated the list. This is what things look like now. I never thought I would enjoy "not" flying this much. Put on the music and relax 5
Elias Posted May 2, 2020 Report Posted May 2, 2020 Hello could you give me the Pn of the trim motor? Thanks. If it is still available.
khedrei Posted May 3, 2020 Author Report Posted May 3, 2020 Pics removed Unfortunately I dont have the yoke trim switch for this system. But I do have a panel mounted trim switch i can throw in for someone that buys it. Looks like a rocker switch. Not ideal but it's all I have right now. The brackets etc are pictured below. P/N for motor is IC373-6-807
Bolter Posted May 7, 2020 Report Posted May 7, 2020 Just a short note that I got the wingtip strobes, today. Exceptionally careful packing, delivered fast, and just as advertised. -dan 1
khedrei Posted May 17, 2020 Author Report Posted May 17, 2020 Some things have sold. I have updated the list as well as prices for things I would like to see gone. Shipping is pretty quick. If you need something please let me know.
Ross Taylor Posted May 27, 2020 Report Posted May 27, 2020 Email and DM sent. Thanks! I'll take the Shadin and the Davtron chrono.
Ross Taylor Posted May 28, 2020 Report Posted May 28, 2020 It's not like @khedrei needs a referral...but I'll give one anyway. I just bought a couple of his items and he was great to work with. He was very clear to point out a couple of possible deficiencies or less-than-perfect issues, with great photos and a chance to change my mind (I didn't!). He shipped them right away and was a pleasure to work with. Go MS! And thank you.
khedrei Posted May 28, 2020 Author Report Posted May 28, 2020 Thanks Ross, It was a pleasure to deal with you as well. I updated the thread again and posted new pictures of remaining stuff as well as some additional items. My boss at the flight school wants me to sell some items that were kicking around his hangar either from him, the private club plane and some from a man that passed and left the airplane stuff to him. In there are a couple of props, wheel hubs, and a 3 axis A/P from a Cessna 182 P as well as some additional avionics. The list is current as of this post. Antennas and KY 197 seem to be spoken for. Just waiting for payment.
carusoam Posted May 29, 2020 Report Posted May 29, 2020 If the wheels belong to a Lancair... @Yooper Rocketman May know a good home for them.... ADF stuff was still popular in Europe for a while... See if @Hyett6420 knows if anyone is still wanting ADF stuff in his area of the .mooney world... Best regards, -a- 1
tmo Posted May 29, 2020 Report Posted May 29, 2020 You do know about the UK CAA ORS4 1362 exempts some cases, and EASA NPA 2020-02 also talks about GPS substitution in the AMC sections? I very well might end up replacing my ADF with an EDM900, if moving the ADF to the right panel ends up being too much work...
