Joe Larussa Posted April 16, 2020 Report Posted April 16, 2020 Can someone point me to where the emergency power bus is located? 77M20J
carusoam Posted April 16, 2020 Report Posted April 16, 2020 Joe, Look into a late 90s M20J... It might be a more modern plane to have that as a standard. It isn’t in my ‘94 O panel... A few parts is all it takes to update a panel to separate things into an emergency bus format... New millennium G1000 planes are probably a good place to look for how their emergency bus is set up... In your 77J the emergency bus is essentially the vacuum line running from the vac pump... PP thoughts only, not a mechanic... Best regards, -a-
Joe Larussa Posted April 16, 2020 Author Report Posted April 16, 2020 Actually just looking to wire an engine instrument so when you turn the master switch on it powers up instead of the avionics master switch.
ArtVandelay Posted April 16, 2020 Report Posted April 16, 2020 Some of the CBs are already tied to master bus instead of the avionics bus.
carusoam Posted April 16, 2020 Report Posted April 16, 2020 As Tom described... Modern Mooneys have a main bus that comes on with the Master... They have a second bus that comes on with the avionics switch... Sounds like you want to connect to anything on the main bus... What kind of instrument do you want to connect? There may be additional info we can noodle through... Many JPI instruments or other engine monitors are on the main, not the avionics... this allows to see engine instruments during the start sequence... Some instruments are sturdy enough to handle crummy power spikes... some are not. PP thoughts only, not a mechanic... Best regards, -a-
Joe Larussa Posted April 16, 2020 Author Report Posted April 16, 2020 It's for the Electronics International FP-5 primary
Joe Larussa Posted April 16, 2020 Author Report Posted April 16, 2020 Route the 3' red wire in the harness to the aircraft’s 12 or 24 volt main or emergency bus as applicable via an independent circuit breaker (five amps or less) This is what the manual says.
Joe Larussa Posted April 16, 2020 Author Report Posted April 16, 2020 The guy that did the install wired it to the avionics master. Long story...
carusoam Posted April 16, 2020 Report Posted April 16, 2020 Have your mechanic decide which of the other existing CBs of 5A or less is best, or if adding another independent CB connected to the main bus is best for you... If there is no room on the bus to have it look nice... somewhere else in the panel connected by a wire is OK too... ‘The guy’ probably wasn’t as good as a good hangar fairy... Want to have some fun? We can ask our EI guy which of your CBs they would select... I saw @M20Doc around... we could ask him... (typical existing CB Used on the main bus to add FF gauge to...?) Best regards, -a-
Joe Larussa Posted April 16, 2020 Author Report Posted April 16, 2020 Lol! Not a hangar fairy but actual A&P
Joe Larussa Posted April 16, 2020 Author Report Posted April 16, 2020 14 minutes ago, carusoam said: Have your mechanic decide which of the other existing CBs of 5A or less is best, or if adding another independent CB connected to the main bus is best for you... If there is no room on the bus to have it look nice... somewhere else in the panel connected by a wire is OK too... ‘The guy’ probably wasn’t as good as a good hangar fairy... Want to have some fun? We can ask our EI guy which of your CBs they would select... I saw @M20Doc around... we could ask him... (typical existing CB Used on the main bus to add FF gauge to...?) Best regards, -a- I like to have fun! I also have a EI Tach and MF pressure gauge that need to same treatment
carusoam Posted April 16, 2020 Report Posted April 16, 2020 Just now, Joe Larussa said: I like to have fun! I also have a EI Tach and MF pressure gauge that need to same treatment Let’s ask the EI guy... @oregon87... Joe if you have details of your CBs on your existing panel... that would minimize any mistakes... (Looking to attach EI instruments to a Mooney M20J panel... which existing CB is recommended, or do I need another added.?..) FF MP RPM best regards, -a-
Joe Larussa Posted April 16, 2020 Author Report Posted April 16, 2020 Just now, carusoam said: Let’s ask the EI guy... @oregon87... Joe if you have details of your CBs on your existing panel... that would minimize any mistakes... (Looking to attach EI instruments to a Mooney M20J panel... which existing CB is recommended, or do I need another added.?..) FF MP RPM best regards, -a- Good Idea! Don't have to many details about the panel I can provide. I added a G5 a while back and they had to add a 5amp breaker elsewhere on the panel.
Guest Posted April 16, 2020 Report Posted April 16, 2020 I don’t have an actual map of the circuit breaker panel layout. You’ll have to check your own to see if you have any spares or un-used ones for your new equipment. Clarence
Joe Larussa Posted April 16, 2020 Author Report Posted April 16, 2020 The instruments have inline fuses, can they be directly wired to the panel but come on with the master switch?
Shadrach Posted April 16, 2020 Report Posted April 16, 2020 54 minutes ago, carusoam said: As Tom described... Modern Mooneys have a main bus that comes on with the Master... They have a second bus that comes on with the avionics switch... Sounds like you want to connect to anything on the main bus... What kind of instrument do you want to connect? There may be additional info we can noodle through... Many JPI instruments or other engine monitors are on the main, not the avionics... this allows to see engine instruments during the start sequence... Some instruments are sturdy enough to handle crummy power spikes... some are not. PP thoughts only, not a mechanic... Best regards, -a- Modern huh? My 53 year old F model came that way from the factory.
bonal Posted April 16, 2020 Report Posted April 16, 2020 1 hour ago, ArtVandelay said: Some of the CBs are already tied to master bus instead of the avionics bus. How on earth do you tie a cheap bastard to a bus sorry I couldn't help myself 1
MikeOH Posted April 17, 2020 Report Posted April 17, 2020 29 minutes ago, bonal said: How on earth do you tie a cheap bastard to a bus Nylon zip ties are pretty strong 2
carusoam Posted April 17, 2020 Report Posted April 17, 2020 1 hour ago, Shadrach said: Modern huh? My 53 year old F model came that way from the factory. Modern in terms of what MS calls modern Mooneys... (after M20F) Joe has a J, so I went with ‘Modern’ in this sense... The only thing modern about my plane... the name Ovation still gets used as the most modern NA Mooney... When MS got set up... it was done quickly and easy... It has evolved a bit in strange ways... Best regards, -a-
Emmet Posted April 17, 2020 Report Posted April 17, 2020 Joe, you should have a schematic of your bus architecture in your POH. In my 231 the busses are made up by a simple connection bar connecting the CBs. That is the location of the busses. Primary engine instruments should be connected to the main and not the avionics bus for obvious reasons. 1 1
ArtVandelay Posted April 17, 2020 Report Posted April 17, 2020 Modern in terms of what MS calls modern Mooneys... (after M20F) Joe has a J, so I went with ‘Modern’ in this sense... The only thing modern about my plane... the name Ovation still gets used as the most modern NA Mooney... When MS got set up... it was done quickly and easy... It has evolved a bit in strange ways... Best regards, -a- They’re really not modern anymore, if Mooney ever creates a modern aircraft we’ll need to rename Modern forum to Classic and create a new modern forum. 1
oregon87 Posted April 17, 2020 Report Posted April 17, 2020 17 hours ago, carusoam said: Let’s ask the EI guy... @oregon87... Joe if you have details of your CBs on your existing panel... that would minimize any mistakes... (Looking to attach EI instruments to a Mooney M20J panel... which existing CB is recommended, or do I need another added.?..) FF MP RPM best regards, -a- As most of our legacy instruments have a power requirement of roughly 1/10 amp, the FP-5(L), M-1 and R-1 can be wired to the master bus via single 1A breaker or fuse. 1 1
