I have a slight cold weather drip from my flap actuator.  Not from the pump.  I see lots of good experience on replacing the seals in the pump on MS but little on the actuator. I would appreciate any learned advice or tricks?  Someone told me the cylinder is a bear to take apart and we may need special tools?
The actuator is a lot easier than the pump. Only hard part is removing it and putting it back in. Bleeding is a lot easier, too.
  • 3 months later...
