hoot777 Posted July 26, 2019 Report Posted July 26, 2019 My poh does not have one. Anybody got one ?? I have a copy of the j models. thanks Quote
carusoam Posted August 15, 2019 Report Posted August 15, 2019 See if you can get the most recent copy of the POH printed for the M20G... an F can provide similar guidance... a J will be close, but not as accurate... Then Find the thread where Chuck N posted his glide experiments... Then develop some rules for yourself for your plane... Topics that get covered... configuration speed weight prop stopped or windmilling slowly... effects of idle power... not nearly the same as a dead engine... procedures glide rings (iPad programs) PP thoughts only, not a CFI... Best regards, -a- 1 Quote
Hank Posted August 15, 2019 Report Posted August 15, 2019 I would expect the G's glide performance to be somewhere between the C and F model. Both of these have numerous uploads in the Documents section; my 1970 C Owner's Manual is there, and it has a Glide Chart in the Performance section just before the Performance Charts used to set engine parameters. The same should be in later F books, too. Gs will have the size and weight of the F, with additional carburetor chin drag of the C. Don't expect to get J model glide performance, there was a lot of aerodynamic work going from F to J. 1 Quote
FloridaMan Posted August 16, 2019 Report Posted August 16, 2019 2 miles for every 1000ft at 100mph. I use it for approximation and planning only. If you know you can make a field and aren’t sure about the airport, take the field. 5 Quote
carusoam Posted October 9, 2019 Report Posted October 9, 2019 Have you seen all the EFBs including glide rings in their apps? Getting it set up properly will work wonders. Best regards, -a- Quote
DXB Posted October 9, 2019 Report Posted October 9, 2019 I would think that an F model would be negligably different from a G in terms of glide performance. Quote
eman1200 Posted October 9, 2019 Report Posted October 9, 2019 Have you seen all the EFBs including glide rings in their apps? Getting it set up properly will work wonders. Best regards, -a- I wonder if anyone sets up their glide rings on the conservative side or exact poh #s..... Quote
carusoam Posted October 10, 2019 Report Posted October 10, 2019 Chuck Noe @cnoe showed us how ‘easy’ it is to generate your own glide numbers to compare with book values... he shared his data and methodology around here somewhere... it’s really interesting as is all comparisons to book numbers... best regards, -a- Quote
Hank Posted October 10, 2019 Report Posted October 10, 2019 2 hours ago, eman1200 said: I wonder if anyone sets up their glide rings on the conservative side or exact poh #s..... Hmmm . . . Guess I should look into the setup. Quote
carusoam Posted October 10, 2019 Report Posted October 10, 2019 Eman... use as exact numbers as possible... Book numbers will have some extra fat baked in... like MGTW numbers... when you go to use them, you will appreciate their accuracy and not making additional assumptions on the fly... PP thoughts only, not a CFI... -a- Quote
0TreeLemur Posted October 10, 2019 Report Posted October 10, 2019 13 hours ago, eman1200 said: I wonder if anyone sets up their glide rings on the conservative side or exact poh #s..... I set it exactly to the numbers so that the glide ring shows the "theoretical maximum" glide distance. Then I know that airports near the ring are "iffy", and those well within are virtually assured targets. Quote
steingar Posted October 10, 2019 Report Posted October 10, 2019 14 hours ago, eman1200 said: I wonder if anyone sets up their glide rings on the conservative side or exact poh #s..... I do. Don't want to get temped to stretch the glide. Guys get killed that way. Quote
