FloridaMan Posted July 20, 2019 Report Posted July 20, 2019 Mag check. Left mag. Doesn’t quit. Struggles. Mixture changes don’t seem to affect it. Quote
FloridaMan Posted July 20, 2019 Author Report Posted July 20, 2019 (edited) Another thought. The slickstart is connected to that mag and the engine starts nearly immediately. That doesn’t seem consistent with the left magneto being bad. Thoughts on what to look at? Bad ignition switch? There is minimal rpm drop between right mag and both mags. Is there a different contact position for “start” than the L/Both for the left mag? Could it be the slickstart screwing up? Edited July 20, 2019 by FloridaMan Quote
carusoam Posted July 21, 2019 Report Posted July 21, 2019 FM, i cant quite follow what you are doing, and seeing... Can you add some step by step detail? Unfortunately, Many with experience are traveling to KOSH today... Best regards, -a- Quote
ArtVandelay Posted July 21, 2019 Report Posted July 21, 2019 If you have an ohmmeter, check for resistance at L, R, Both positions. Obviously do this with Master off. I would also do a visual check of the magnetos, gently pull on the wires to make sure it’s not a broken wire connection.Tom Quote
DMM Posted July 21, 2019 Report Posted July 21, 2019 Its hard from to tell from the video but it appears that cylinder 2 and 3 EGT start dropping on left mag and the engine is running on two cylinders. I'd start by looking at those ignition leads and plugs. Quote
Yetti Posted July 21, 2019 Report Posted July 21, 2019 Start with plugs. Mag timing. Slickstart is out of the loop after starting sequence is finished. Quote
FloridaMan Posted July 23, 2019 Author Report Posted July 23, 2019 (edited) It was a bad coil. This was my third time in 7 years of Mooney ownership being stuck AOG away from home (if you don’t include that engine failure). KLQK might be the best place I’ve ever been broken down. I ended up going to college bars around Clemson for three nights in a row and I suspect that the total repair combined with what I spent might have been cheaper than if it had happened at home. The shop was able to repair my mag with a serviceable coil and I was on my way for less than $500. Edited July 23, 2019 by FloridaMan 2 Quote
nfonville Posted July 23, 2019 Report Posted July 23, 2019 Dealt with that same issue last year. My left mag was completely dead but yet the engine started up easily with the slickstart. My starter turned the prop fast enough the right mag was able to fire the engine. The issue in the mag was a broke capacitor wire. Champion 6300 series mag on my Mooney Bravo. I would pull and have the mag inspected. Quote
Yetti Posted July 23, 2019 Report Posted July 23, 2019 8 hours ago, FloridaMan said: It was a bad coil. This was my third time in 7 years of Mooney ownership being stuck AOG away from home (if you don’t include that engine failure). KLQK might be the best place I’ve ever been broken down. I ended up going to college bars around Clemson for three nights in a row and I suspect that the total repair combined with what I spent might have been cheaper than if it had happened at home. The shop was able to repair my mag with a serviceable coil and I was on my way for less than $500. How many hours on that mag? Quote
FloridaMan Posted July 25, 2019 Author Report Posted July 25, 2019 On 7/23/2019 at 4:15 PM, Yetti said: How many hours on that mag? < 200 and 2 years Quote
carusoam Posted July 26, 2019 Report Posted July 26, 2019 Great follow-up, FM/Antares... Any warranty on parts or labor at All? Best regards, -a- Quote
