mike20papa Posted May 26, 2019 Report Posted May 26, 2019 All I can add is that the position of the trim for take off can make a big difference in the way the AC handles during take off. Not enough up trim and it can be a handful .. I mean a feets full experience. Get the trim position set so that you don't have to hold back pressure on the yoke during take off to keep it from "over steering" - darting like a squirrel right/left and then it will climb out with little yoke effort, re-trimming. It took me a long time to finally get this just right. 1 Quote
chriscalandro Posted May 26, 2019 Report Posted May 26, 2019 This is with my I doctor centered on my TO position. I always end up trimming it forward a bit just after wheels up. 1 Quote
Prior owner Posted May 27, 2019 Author Report Posted May 27, 2019 8 hours ago, chriscalandro said: This is with my I doctor centered on my TO position. I always end up trimming it forward a bit just after wheels up. Thanks for the pic! Quote
S.C. Posted May 27, 2019 Report Posted May 27, 2019 On 5/24/2019 at 10:00 AM, carusoam said: SC, That is some quirky advice to have received... Some M20C Pilots were given the advice..... you can never get enough up trim in a Mooney... as there is plenty of up trim used when landing flaps are used... And again plenty of up trim used when the back seats are empty.... But... T/O with the same up trim as landing... that will most likely have the plane’s nose pointing towards the sky under full power... Was your experience anything like this? PP thoughts only, not a CFI... Best regards, -a- Yes, it was a bit odd at first, but he’d been flying the plane for a while so, I went with the advice given. That’s why I crank down after landing so I don’t have so much nose up on T/O. All of us have a different feel. The great part is, he is my mentor, so we’ve discussed, laughed and shared a beer over the topic. We’ve flown together since and he doesn’t use as much trim on landing which is why the advice seems to have made more sense. 1 Quote
PT20J Posted May 27, 2019 Report Posted May 27, 2019 On 5/26/2019 at 10:48 AM, chriscalandro said: This is with my I doctor centered on my TO position. I always end up trimming it forward a bit just after wheels up. You might try aligning the elevator with the stabilizer for a few takeoffs. You will have to pull back a bit to lighten the nosewheel for takeoff (piston planes don’t really “rotate”) and relax the pressure as it accelerates in climb, but you shouldn’t need to touch the trim until you raise the flaps. Quote
Herlihy Brother Posted June 5, 2019 Report Posted June 5, 2019 RE takeoff trim on my 1964 E, I was taught 20 years ago to look over my shoulder and make sure the elevator is aligned with the stabilizer for takeoff... After liftoff, I add about a quarter turn of nose down trim wheel to climb out at 130mph ias or so Quote
RogueOne Posted June 11, 2019 Report Posted June 11, 2019 On 5/27/2019 at 3:59 PM, PT20J said: You might try aligning the elevator with the stabilizer for a few takeoffs. You will have to pull back a bit to lighten the nosewheel for takeoff (piston planes don’t really “rotate”) and relax the pressure as it accelerates in climb, but you shouldn’t need to touch the trim until you raise the flaps. If you do, is it a big deal? Just trim the plane. No biggie. Quote
PT20J Posted June 11, 2019 Report Posted June 11, 2019 1 hour ago, RogueOne said: If you do, is it a big deal? Just trim the plane. No biggie. Well, I think the object is to get a smooth takeoff with a minimum of fuss. As Bob Kromer pointed out at MooneyMAX last week, a steady 5 lb. pull during the takeoff roll will give a smooth liftoff. But, it only works if the trim is set right. Skip Quote
S.C. Posted June 11, 2019 Report Posted June 11, 2019 On 5/24/2019 at 10:00 AM, carusoam said: SC, That is some quirky advice to have received... Some M20C Pilots were given the advice..... you can never get enough up trim in a Mooney... as there is plenty of up trim used when landing flaps are used... And again plenty of up trim used when the back seats are empty.... But... T/O with the same up trim as landing... that will most likely have the plane’s nose pointing towards the sky under full power... Was your experience anything like this? PP thoughts only, not a CFI... Best regards, -a- -a- It was quirky advice, but having flown with the pilot I bought the plane from it makes sense, we all fly a little differently. He was light on the trim, and likes to control with the yolk. I am much heavier on the trim than yolk, so for me taking off with the same landing trim for take off did exactly what you described. I was having to force the yolk forward during take off, and after the Johnson Bar was locked in place found myself cranking the trim wheel to get to 500fpm climb. Now I consciously roll the trim nose forward as I taxi back to the hanger. It’s a penciled in part of my post flight check list. (But I still roll the trim wheel forward during pre-flight to be double sure). Best, S.C. 1 Quote
Greg Ellis Posted June 11, 2019 Report Posted June 11, 2019 1963 C model. This is a photo of my elevator with the trim in T/O position. Compared to Chris Calandro, mine is pretty even with the horizontal stabilizer. 1 Quote
RogueOne Posted June 11, 2019 Report Posted June 11, 2019 14 hours ago, PT20J said: Well, I think the object is to get a smooth takeoff with a minimum of fuss. As Bob Kromer pointed out at MooneyMAX last week, a steady 5 lb. pull during the takeoff roll will give a smooth liftoff. But, it only works if the trim is set right. Skip It is rarely (for me) zero trim input to get it just right. It is not fussy or unsmooth. It is not a lot of input, but rather a small roll for “just right”. I think it is great that you have the trim position so well positioned that you have no input. I don’t fly my Mooney off. I pull to break roll based on indicated airspeed. Glad your technique works. I regularly adjust trim before and after flaps are raised. The input is a non-event. Quote
Hank Posted June 12, 2019 Report Posted June 12, 2019 This is what I do: trim on Takeoff if heavy, half the mark Nose Up if light. At 70 mph, pull on yoke then relax some pull when airborne. Like it says here: 1 Quote
