daytonabch04 Posted November 20, 2020 Report Posted November 20, 2020 I’m at oil change now and was just told 4x fine wire spark plugs were cracked at the base. My annual was only 30-40 hours ago and somehow missed. Of course they don’t carry fine wire plugs on hand so he recommended switched either 6 or all 12 to massive spark plugs. I chose to switch all 12 instead running 6 and 6 of each. I run mostly ROP so hopefully I won’t see too many issues over the short term. Quote
alextstone Posted November 20, 2020 Report Posted November 20, 2020 I’m at oil change now and was just told 4x fine wire spark plugs were cracked at the base. My annual was only 30-40 hours ago and somehow missed. Of course they don’t carry fine wire plugs on hand so he recommended switched either 6 or all 12 to massive spark plugs. I chose to switch all 12 instead running 6 and 6 of each. I run mostly ROP so hopefully I won’t see too many issues over the short term. What brand were the fine wires?Sent from my Pixel 3 XL using Tapatalk Quote
LANCECASPER Posted November 21, 2020 Report Posted November 21, 2020 4 hours ago, daytonabch04 said: I’m at oil change now and was just told 4x fine wire spark plugs were cracked at the base. My annual was only 30-40 hours ago and somehow missed. Of course they don’t carry fine wire plugs on hand so he recommended switched either 6 or all 12 to massive spark plugs. I chose to switch all 12 instead running 6 and 6 of each. I run mostly ROP so hopefully I won’t see too many issues over the short term. My Bravo runs much smoother on fine wire plugs. The cracks would have happened on fine or massive if over-torqued. 1 Quote
daytonabch04 Posted November 23, 2020 Report Posted November 23, 2020 On 11/20/2020 at 6:26 PM, alextstone said: What brand were the fine wires? Sent from my Pixel 3 XL using Tapatalk Champion Quote
Danb Posted November 24, 2020 Report Posted November 24, 2020 Lance my Bravo also runs great on tempest fine wires also, I had Champion fine wires for 120 hours of which 4 of 12 failed switched to tempest with perfection 3 Quote
Seth Posted November 24, 2020 Report Posted November 24, 2020 I haven't read anything - but wanted to quickly chime in. If running ROP, it doesn't matter. If running LOP, fine wire tempest made such a difference over massive champions for me in an IO550A. So much so that I'm amazed by it. I could run LOP but could "feel" it ever so slightly with the champions. With the tempest, there is no way to tell I'm running LOP from the feel. It runs just fine. Significant fuel savings for just a few knots slower and a cleaner running engine with no negative vibration. -Seth 1 Quote
Cruiser Posted November 24, 2020 Report Posted November 24, 2020 Are Tempest Fine Wire plugs approved for the IO-550G engine ? Quote
carusoam Posted November 25, 2020 Report Posted November 25, 2020 9 hours ago, Cruiser said: Are Tempest Fine Wire plugs approved for the IO-550G engine ? Let’s see if @StevenL757 is around (fine wire question) Best regards, -a- 1 Quote
StevenL757 Posted November 25, 2020 Report Posted November 25, 2020 9 hours ago, Cruiser said: Are Tempest Fine Wire plugs approved for the IO-550G engine ? Yes You need Tempest part# URHB32S 1 Quote
