Marauder Posted October 17, 2018 Report Posted October 17, 2018 I saw the discussion regarding the 135 degree turns. Next time I fly, I will fly one that has at least 135 degrees. I calculated the highest angle on the flight I did and it was only 98 degrees. I have a couple other waypoints I could use that will give me in excess of 180 degrees. When I looked at my Garmin Pilot track afterwards, saw a funny anomaly. Where I did my runup, it looked like a little explosion.
Marauder Posted October 17, 2018 Report Posted October 17, 2018 And for entertainment only value, this is the coupled approach I flew after the waypoint experiment. I am testing out a new GoPro in preparation for some updates videos on the Aspen and Lynx units. No audio, that will come later. And for those of you wondering why I side stepped to the right, there was a Citation that took off just before I got to the DA. Did not want to fly into his wake on the missed approach. Sent from my iPhone using Tapatalk Pro 2
flyboy0681 Posted October 17, 2018 Report Posted October 17, 2018 1 hour ago, Marauder said: And for entertainment only value, this is the coupled approach I flew after the waypoint experiment. I am testing out a new GoPro in preparation for some updates videos on the Aspen and Lynx units. No audio, that will come later. And for those of you wondering why I side stepped to the right, there was a Citation that took off just before I got to the DA. Did not want to fly into his wake on the missed approach. Great video. How did you mount the camera? I tried using the sticky mount on the headliner but it simply won't adhere. 1
carusoam Posted October 18, 2018 Report Posted October 18, 2018 It’s really cool being in Marauder’s cockpit! Now we see what he sees... Right through his glasses... Thanks for sharing the video, Chris. Its an interesting viewpoint at near eye level... the center of rotation around the axis is really accentuated... Best regards, -a-
DualRatedFlyer Posted October 18, 2018 Report Posted October 18, 2018 14 hours ago, Marauder said: And for entertainment only value, this is the coupled approach I flew after the waypoint experiment. I am testing out a new GoPro in preparation for some updates videos on the Aspen and Lynx units. No audio, that will come later. And for those of you wondering why I side stepped to the right, there was a Citation that took off just before I got to the DA. Did not want to fly into his wake on the missed approach. Sent from my iPhone using Tapatalk Pro Hook me up with a link for that Ipad mount. I have been toying with adding something under the throttle quadrant, but am afraid itll encroach on my leg space. I like how yours is offset.
Marauder Posted October 18, 2018 Report Posted October 18, 2018 Great video. How did you mount the camera? I tried using the sticky mount on the headliner but it simply won't adhere. The standard GoPro mount stuck fine. You may need to clean the area with some alcohol to get an unseen dirt & grime off.Sent from my iPad using Tapatalk Pro
Marauder Posted October 18, 2018 Report Posted October 18, 2018 Hook me up with a link for that Ipad mount. I have been toying with adding something under the throttle quadrant, but am afraid itll encroach on my leg space. I like how yours is offset. It is this gizmo from mygoflight. The ashtray was removed and replaced with a flat metal plate.Sent from my iPad using Tapatalk Pro
Marauder Posted October 18, 2018 Report Posted October 18, 2018 Hook me up with a link for that Ipad mount. I have been toying with adding something under the throttle quadrant, but am afraid itll encroach on my leg space. I like how yours is offset. And BTW, I have a magnetic mount on the yoke and the metal plates on the back of the iPad. If it gets in the way of the passenger, I plop the iPad back on the yoke where the iPhone I was playing with was located.Sent from my iPad using Tapatalk Pro
MarcK Posted October 20, 2018 Report Posted October 20, 2018 I think this is probably correct behavior. The IFD will start a turn within 2.5 miles of the waypoint, as a fly-by. If the turn angle is greater than 135 degrees, it would need to start the turn much earlier to not overshoot the outbound course. By overflying the waypoint before turning to the outbound course it is possible to stay in protected airspace. For example, at 150 Kts, the turn diameter at standard rate is only 1.6 Nm. Without GPSS, navigation would normally be fly-over, and this is no different. A direct turn to the outbound course would overshoot and require an S-turn correction. This method gets you on course closer to the waypoint. Garmin doesn't document what it does for the GTN series, though it is possible to select either fly-over or fly-by on a G1000.
jetdriven Posted October 20, 2018 Report Posted October 20, 2018 A GNS530 commands a correct turn anticipation for a 150 degree course change beucause I’ve seen that. flying over the waypoint Keeps you within 4nm of course centerline right up until it sends you out the side at nearly 90 degree. That’s not normal behavior.
MarcK Posted October 20, 2018 Report Posted October 20, 2018 7 hours ago, jetdriven said: A GNS530 commands a correct turn anticipation for a 150 degree course change beucause I’ve seen that. flying over the waypoint Keeps you within 4nm of course centerline right up until it sends you out the side at nearly 90 degree. That’s not normal behavior. I don't have any GPS, so I'm not going to argue too much for either. But you would need to be going faster than 300 Kts for a standard rate turn to take you more than 4nm from the centerline.
Jon W Posted February 10, 2025 Report Posted February 10, 2025 I realize this is an old thread, but I will put this information out in hopes it can help someone else with the same issue. S-TEC 60, 60-2, 65, 55, 55X are all rate based autopilots and are limited by design to 90% standard rate as sensed by the rate source (turn coordinator gyro with rate outputs in most installations). We've seen this overshoot issue on a Cessna Skymaster with a S-TEC 65, and were able to find published in the autopilot Pilot's Guide the 90% standard rate turn limitation. This limitation applies to their other rate based autopilots as well.
0TreeLemur Posted February 19, 2025 Report Posted February 19, 2025 By coincidence I tried this exact test just Sunday. I had a turn of 290 degrees programmed in the IFD540 just to see what it would do. I expected it to anticipate the turn. With the Aspen in GPSS mode, KFC150 A/P in HDG mode. To my surprise the IFD took me over the waypoint and turned left 290 degrees. It seems that there is still some limit in the IFD software, where beyond a certain angle it requires a flyover. Good to know. I tried again and anticipated the turn using the heading bug in non-GPSS mode, and that works. Threads from the past like this one are very useful.
