MBDiagMan Posted September 12, 2018 Report Posted September 12, 2018 1 hour ago, Marauder said: I agree. Sent from my iPad using Tapatalk Pro When I bought the 345, the Lynx cost $1,000 more. They are on sale now for virtually the same price. I wish I hadn’t been such a CB and would have gotten the Lynx. 1 Quote
bill98 Posted September 12, 2018 Author Report Posted September 12, 2018 If I got the Lynx or 345, does anyone think I should move the location towards the center? Also - Anyone know how to light up the Fuel QTY gauges from behind or directly above? Quote
LANCECASPER Posted September 12, 2018 Report Posted September 12, 2018 41 minutes ago, bill98 said: If I got the Lynx or 345, does anyone think I should move the location towards the center? Also - Anyone know how to light up the Fuel QTY gauges from behind or directly above? Since the Lynx has a display having it in the center would be better, but not completely necessary. If the switches above the audio panel coved be moved . . maybe Quote
bill98 Posted September 12, 2018 Author Report Posted September 12, 2018 22 minutes ago, LANCECASPER said: Since the Lynx has a display having it in the center would be better, but not completely necessary. If the switches above the audio panel coved be moved . . maybe Know anything regarding having the Fuel gauges light up on the panel? I have zero idea of it is possible. Quote
MBDiagMan Posted September 12, 2018 Report Posted September 12, 2018 The 345 would fine in the current transponder location. The Lynx would be better in the center stack. Moving the KX would make room although you might want rearrange the stack. My $0.02, 1 Quote
MIm20c Posted September 12, 2018 Report Posted September 12, 2018 22 minutes ago, bill98 said: Know anything regarding having the Fuel gauges light up on the panel? I have zero idea of it is possible. For night/every flight I really don’t use the fuel gauges all that often (cross check vs first place to look). Instead the JPI fuel used is carefully observed (i note the remaining amount every time I switch tanks) which allows me to know fuel remaining in tank to the half gallon. I have the 231 gauges in my plane so I’m not sure about lighting. Quote
Igor_U Posted September 12, 2018 Report Posted September 12, 2018 37 minutes ago, bill98 said: Know anything regarding having the Fuel gauges light up on the panel? I have zero idea of it is possible. You could install post lights, similar to instrument lights your Mooney had on plastic overlay you have it removed. well, at least my '67 has 3 lights above instrument cluster on plastic overlay... Quote
Marauder Posted September 12, 2018 Report Posted September 12, 2018 If I got the Lynx or 345, does anyone think I should move the location towards the center? Also - Anyone know how to light up the Fuel QTY gauges from behind or directly above? I think if you moved the stuff above the audio panel to other locations, you would be able to move the audio panel up and slide a Lynx in.I have an F but I think it should fit. I would just check the depth of the audio panel. Sent from my iPad using Tapatalk Pro 1 Quote
Hank Posted September 13, 2018 Report Posted September 13, 2018 4 hours ago, bill98 said: Know anything regarding having the Fuel gauges light up on the panel? I have zero idea of it is possible. The factory fuel gages on my 1970 are lit. I'll check my phone for a picture . . . . 1 Quote
bill98 Posted September 13, 2018 Author Report Posted September 13, 2018 I made a mountain out of a molehill. It looks very simple to add a tiny light or strip in the area. Quote
