No mention of engine time or condition.  So, you may have to add price of overhaul or complete engine to purchase price. No mention of damage history or lack thereof, so look the logs over carefully.  Strange that they did not claim the one piece windshield or other mods. Looks like someone cared so might be worth a look.
Database Update Cycle
Aircraft Registration: Last 04/18/11 (weekly cycle) SDR: Last 04/18/11 (weekly cycle)
NTSB Data: Last 04/18/11 (weekly cycle) FAA Accident: 04/18/11 (weekly cycle)
Aircraft Information
Owner Type: Corporation Owner Name: BRANSON AVIATION LLC
City: FORSYTH State: MO
Zip: 65653-0100 Country: US
Fractional Owner:
Aircraft Type: Fixed wing single engine Model Year:
Airworthiness Class: Transponder Code: 50053146
Serial Number: 2605 Aircraft Model: 5870208
Last Action: 2010-04-20 Cert Issue: 2007-04-13
Status: Triennial Aircraft Registration form was returned by the Post Office as undeliverable
Aircraft Mfg: MOONEY Aircraft Model: M20C
Category: Land Amateur: No
Engines: 1 Seats: 4
Weight: CLASS 1 Cruising Speed: 127
Engine Mfg.: Engine Model:
Fuel Consumed: 0.00 Horsepower/Thrust:
Service Difficulty Report (SDR) Information
#SDR1
Report Date: 2006-02-28 Occurrence Date: 2005-03-14
Aircraft Name: MOONEY Aircraft Group Code: M20
Aircraft Manufacturer Num: 2605 Engine Mfg.: LYC
Aircraft Type Certificate: 2605 Engine Model: O360A1D
Propeller Mfg. Name: Propeller Model:
Carrier Code: Operation Type: G
Failed Part Information
Name: IDLER GEAR Aircraft Location: ENGINE
Condition: DAMAGED Model:
Manufacturer Name: Total Time: 3560
Manufacturer Num: Since Overhaul: 1639
Manufacturer Part Num: 75072
Jasc Desc: Reciprocating Engine Power Section
Segment Desc: ENGINE
Severity Desc:
Stage Desc: NOT REPORTED
Submitter Desc: MECH
Procedures: OTHER
Conditions: OTHER
Remarks: ENGINE FAILED IN FLIGHT PRELIMINARY INSPECTION REVEALED CAMSHAFT AND ASSOCIATED CRANKSHAFT IDLER GEAR WAS SEPARATED FROM CRANKSHAFT DRIVE GEAR IDLER GEAR SLOWS EVIDENCE OF DAMAGE TO DRIVE TEETH. UNABLE TO DETERMINE AT THIS TIME WHETHER THE CAMSHAFT OR LT MAGNETO DRIVE WAS RESPONSIBLE FOR IDLER GEAR DAMAGE AND ENGINE FAILURE. (K)
NTSB Accident Information
No NTSB Accident Reports Found
FAA Accident/Incident Information
#FAA1
Accident/Incident Occurred on: 1978-11-06
Narrative: PILOT FAILED TO EXTEND GEAR BEFORE TOUCHDOWN.
#FAA2
Accident/Incident Occurred on: 2005-02-08
Narrative: (-23) 02/09/05-ON SCENE INVESTIGATION CONDUCTED OF ACFT INCIDENT. 02/08/05 @ 1645 MOONEY, N1202X, M20C, WAS ENROUTE FROM N52 TO RUQ AND LOST POWER AT APPROXIMATELY 2,500 FEET AGL AND LANDED GEAR UP IN A CORN FIELD APPROXIMATELY 2 MILES SOUTH OF ROCKWELL, NC. ONLY VISIBLE DAMAGE WAS TO THE PROP, BENT TIPS SLIGHTLY, AND BELLY ANTENNAS TORN OFF. NO OTHER DAMAGE WAS NOTICEABLE. ACFT TO BE MOVED TO SALISBURY AIR SERVICE FOR TEAR DOWN. 02/24/05-THIS INSPECTOR SPOKE WITH THE MECHANIC WHO HAS PERFORMED AN ON SCENE INVESTIGATION OF THE AIRCRAFT AND MECHANIC STATED THAT HE TOOK THE VALVE COVERS OFF AIRCRAFT AND THAT THE VALVES WERE NOT MOVING WHEN ATTEMPTED TO TURN ENGINE OVER, INDICATING A POSSIBLE CAM SHAFT BREAK. ACFT IS STILL AT THE FIELD WHERE IT CRASHED.
Quote: Skywarrior
1880 SMOH, so that's one reason.
Off-field landing, plus a gear-up, so that's two reasons.
Chuck M.
Chuck M.
I think the gearup/belly landing is less a factor than was a new prop installed(bent tips)and a major overhaul acomplished after the power failure.It would be hard to believe the engine was not done at that time considering the lower end damage found on tear down..so if you can stand the yeller peril paint job...could be a good buy at 30k....esp with the 430 installed, and other mods windshields etc..my 2 cents
Old gear ups are common , The idler gear failure may have been fixed without tear down , if the damage was localized it may have had an accesory case and gears , the engine shut down when the gear failed...(no mags turning) ...  But you can get a lot of mooney for the money now ..  good luck
