Stetson20 Posted May 14, 2021 Report Posted May 14, 2021 On 4/29/2021 at 1:20 AM, 75_M20F said: 3" EXTENSION PEDALS - 720115-504 — LASAR Out of stock.. Quote
Stetson20 Posted May 14, 2021 Report Posted May 14, 2021 Anybody got a pair for sale? 5’8” here. Would be nice to sit back a bit. Quote
PT20J Posted May 14, 2021 Report Posted May 14, 2021 39 minutes ago, Stetson20 said: Out of stock.. Did you call Dan at LASAR. They are not stocking as much as they used to but can order from the factory which will drop ship to you. Also, remember that the 1.5" extensions come as a set for both pilot's pedals, but for the 3" you have to order two -- one for each pedal. I have a set of 1.5" extension brackets if anyone needs them. Skip 1 Quote
Stetson20 Posted May 15, 2021 Report Posted May 15, 2021 3 hours ago, PT20J said: Did you call Dan at LASAR. They are not stocking as much as they used to but can order from the factory which will drop ship to you. Also, remember that the 1.5" extensions come as a set for both pilot's pedals, but for the 3" you have to order two -- one for each pedal. I have a set of 1.5" extension brackets if anyone needs them. Skip I’ll call. Thanks! Quote
Aerodon Posted May 18, 2021 Report Posted May 18, 2021 I'm making slow progress, its hard to get the attention of a machine shop to do small jobs. Had the parts laser cut, but that shop could not do the bending. Had another shop do the joggle in the side pieces, they did a really nice job. Just waiting for them to do the centre piece. Aerodon 1 Quote
TAF Posted December 12, 2021 Report Posted December 12, 2021 On 4/3/2018 at 7:57 PM, DonMuncy said: I looked back in older posts and found where someone posted the drawings for the 3 inch extensions. (Thanks to those folks) My hangar elf was busy today and turned out a set. They are not all that difficult. Mine are not perfect, but it appears that none of the dimensions are critical. You do have to make sure that the spacing for the holes are identical for both sides of the same pedal. Quote
Alec Posted September 23, 2022 Report Posted September 23, 2022 Does anyone have any 3" rudder pedal extensions, maybe even with the rudder pedals made special for the extensions so the pedals are at the correct angle vertically? Quote
PT20J Posted September 23, 2022 Report Posted September 23, 2022 54 minutes ago, Alec said: Does anyone have any 3" rudder pedal extensions, maybe even with the rudder pedals made special for the extensions so the pedals are at the correct angle vertically? There are no special pedals. The installation instructions for the 3 inch extensions show how to modify the 720017-007 pedals when you install the kit. When you order the kit, you have to order two as the kit only has parts for one pedal unlike the 1.5” extension kit that has parts for both pedals. After installing, you have to remove the left exhaust cavity and adjust the brake cylinder rod lengths to correct the pedal angle. Skip Quote
Deni Posted May 10, 2023 Report Posted May 10, 2023 On 5/14/2021 at 10:46 PM, DonMuncy said: Yes, but since I wanted 3 inch ones anyway I went ahead and made them 3 inch. Dear Don PLEASE send me drawings for pedal extenders for K model to avoid waiting from factory here or sazdoprop@gmail.com Thanks A LOOT Quote
Pinecone Posted May 10, 2023 Report Posted May 10, 2023 On 9/22/2022 at 11:34 PM, PT20J said: After installing, you have to remove the left exhaust cavity and adjust the brake cylinder rod lengths to correct the pedal angle. Assuming you have the adjustable links. My plane came with 3 inch extensions, but fixed links (Encore conversion). I found one link from LASAR at about $300. The other was ordered from the factory through Maxwell and was over $600. If I had the time, I would have done an owner produced part, the materials would be about $75. 1 Quote
Fly Boomer Posted May 10, 2023 Report Posted May 10, 2023 On 9/22/2022 at 10:34 PM, PT20J said: After installing, you have to remove the left exhaust cavity and adjust the brake cylinder rod lengths to correct the pedal angle. Do you have, or can you point me to some documentation on this? Quote
PT20J Posted May 10, 2023 Report Posted May 10, 2023 2 minutes ago, Fly Boomer said: Do you have, or can you point me to some documentation on this? Nope. It’s not described in the Service and Maintenance Manual. Quote
Fly Boomer Posted May 10, 2023 Report Posted May 10, 2023 Just now, PT20J said: Nope. It’s not described in the Service and Maintenance Manual. Thanks. I guess we'll figure it out. Quote
PT20J Posted May 10, 2023 Report Posted May 10, 2023 Just now, Fly Boomer said: Thanks. I guess we'll figure it out. It’s pretty simple and doesn’t require disconnecting anything. Just loosen the jam nut on the master cylinder piston rod clevis and rotate the piston rod to adjust the angle. It doesn’t take much because of the geometry, so rotate it maybe one turn at a time checking between adjustments. 1 Quote
Pinecone Posted May 10, 2023 Report Posted May 10, 2023 I don't think @jetdriven did that. I am pretty sure they did it by accessing from cockpit Quote
salty Posted May 10, 2023 Report Posted May 10, 2023 I had to turn quite a few times, and I did it from underneath. Not to derail, but I have a set of pedals with the extensions installed already if someone is interested. Quote
DonMuncy Posted May 11, 2023 Author Report Posted May 11, 2023 On 5/10/2023 at 5:31 AM, Deni said: Dear Don PLEASE send me drawings for pedal extenders for K model to avoid waiting from factory here or sazdoprop@gmail.com Thanks A LOOT I finally found my (apparently factory) drawings of both the 1 1/2 and 3 inch ones. If these don't come through, let me know.Drawing 720115.pdf Quote
Fly Boomer Posted May 11, 2023 Report Posted May 11, 2023 3 minutes ago, DonMuncy said: I finally found my (apparently factory) drawings of both the 1 1/2 and 3 inch ones. If these don't come through, let me know.Drawing 720115.pdf Drawing looks good. Quote
Robby_H Posted April 5, 2024 Report Posted April 5, 2024 On 5/10/2023 at 10:56 AM, salty said: I had to turn quite a few times, and I did it from underneath. Not to derail, but I have a set of pedals with the extensions installed already if someone is interested. @salty Just brought a M20J. Interested in the extensions if you still have them. Quote
PT20J Posted April 7, 2024 Report Posted April 7, 2024 On 4/5/2024 at 7:10 AM, Robby_H said: @salty Just brought a M20J. Interested in the extensions if you still have them. Check the equipment list in the POH. Some came from the factory with 1.5” extensions installed (mine did). If so, you will need the 3” extensions. Quote
Aerodon Posted January 4 Report Posted January 4 If you were to ask me to make an OPP (owner produced part) according to drawing 720115 for 3” extensions I could do that for you. aerodon 2 Quote
M20F-1968 Posted January 5 Report Posted January 5 Another reason for installing 3" Rudder Pedal Extensions: I have wide shoulders, and had 1 1/2" extensions installed but still felt cramped by the L side panel. I installed 3" extensions on the pilot side only and feel less constrained. Food for thought. I have 3 holes exposed in the seat rails and the seat locks into the 4th hole. The Ovation (from which I obtained my brake system) comes with 1 1/2" extensions. Quote
Pinecone Posted January 5 Report Posted January 5 Can you make the adjustable brake links for a reasonable price? Quote
JCCV Posted April 10 Report Posted April 10 On 4/3/2018 at 7:07 PM, DonMuncy said: Incidentally, I now have a surplus set of the 1 1/2 inch extensions, it anyone is interested. They are really not difficult for a hangar elf to install. Do you still have extension? Quote
