1 hour ago, DXB said:
Could be the fastest NA Mooney in existence.  No J bar though - I’ll pass :P
Interesting. The last photo looks to have an electric gear selector way down at the bottom of the panel, and a J bar to the right of the mixture, hidden by the writing.
It's advertised as a 2005 "year of fabrication" based on the mods, but doesn't mention what year the airframe is . . . Afraid to scare off buyers?  ;)
How hard is it in the US to turn an old certified aircraft to an experimental with no limitations?  Don’t see many certified Planes go that route even though many old airframes are pennies on the dollar.
Here, I think it can only be done as "Experimental / Exhibition" which precludes personal use, travel, etc., or temporarily to collect data for STCs, etc.
Experimental exhibition airplanes (EE) airplanes are not a big deal. Program letter and a genorious FSDO they aren't a problem. But having one as a personal airplane for daily use might be more of a challenge.
Bringing somthing back to certified takes a DAR with function codes On par with God himself. I took a 1year old helicopter in the EE category back to certified. Took 5 days. There were 2 people west of the Mississippi that could do it. Geographical extensions are required.
looks like a really neat airplane. With the Lower VNE it be hard to use all that 300hp.  Still sweet!!!
I hope they re-engineered the engine mount. The stock mount attaches with really tiny hardware.
-Matt
Imagine what the climb rate is, solo with half tanks!!  :o
  • Sad 1
1) Gonna need a new VSI... Expect above 2k’pm in cold OATs...
2) Gonna Want That automated mixture control as that 5 minute time to climb is going to keep you busy...
1 hour ago, gsengle said:
How’d they balance that engine w&b wise!
Guaranteed the battery was moved from the firewall to as far aft as possible. Looks like the back seat was slid aft, too, as my front seats touch it when slid back to enter / exit the plane. Does make you wonder what else was done.
I would think at least two batteries or weights (both?) were used.  With my turbo system and two external oil filters my battery needed to be moved to the back.
That's not enough.
Already the rocket/missile conversion required putting TWO large 35mAMP batteries in a tray in the way way back of the tail.  The M20C is shorter.  Seems like they would need a rod sticking outside the airplane another 2 ft with a bag of lead shot!
There must be a bag of lead in the way back of the tail.
I bet it'd do near 3000fpm on the coldest days.
Edited by Shadrach
  • Sad 1
