594b105ea8649_ScreenShot2017-06-21at7_28_36PM.png.56e9ac74959ebbcae66f8100aa006cdc.png
Hi fellow MS'ers. My KY 197 is kaput. The display is wonky with digit segments dropping or persisting so it is difficult/impossible to validate that the correct channel is selected. The swap button  only works after a few tries and then much of the time it won't bring in a channel. ..basically it is toast. I have called and can have it overhauled for around .5AMU but wanted to see if anyone had one sitting around a shelf ornament that works that would like to git rid of it cheaply so I can just plug in a replacement. Basically the goal is to get a working com to provide a working COM2 to my current COM1 (530W). PM me if you have something that might fit the bill.
Thanks,
Stephen
Thanks Paul, at least appreciate the thought! I may just sent the dumb thing in; but wanted to shake the MS tree to see if anyone had a 197 gathering dust.
The display just plugs into a socket. Often reseating it will fix the missing segments. Just remove the front to access it.
Yeah, I've done that with my KX155 but that won't help the swap issue.
I sold a 197 out of my old panel 5 years ago on EBAY for $625. Bennett Avionics bought it!
I'll give that a try; maybe it will at least help the display portion.
20 hours ago, jerryg324 said:
I just happen to have one available...  Just pm me...
Purchased; thanks Jerry!
