Lycoming engines had several different TBO's depending on internal configuration.  Valves stems, bearing dowels etc all were factors.
See Lycoming SI 1009 it covers the subject.
Clarence, and I think TBO have been increased from the time the were introduced, presumably based on accumulated data. My current IO360 A1A used to have a 1600 TBO or even lower compared to the 2000 it has now.
This and similar derivative charts are plagued with transcription errors. e.g., the engine model for the E, F is the A1A, not A1D, The F does not have 4.4 seats, and I suspect the F's VSo in not different from the G model. And I doubt that the performance number for the C and E remained the same over the years as speed claims became more realistic.
18 hours ago, teejayevans said:
There is a summary of Mooney models you'll find but in every case it's truncated, missing Js and later...anyone have a full version?
I attended the MAPA Safety seminar a few months ago (highly recommended) and they have a section of the curriculum that has a more complete version. It’s a copyrighted material so I won’t post it, but maybe someone from MAPA is lurking and can provide it as a service to the folks here.
