Patto Posted September 12, 2016 Report Posted September 12, 2016 See attached. I had been hearing a rattling/clanging noise and found the culprit under the rear seat cushion. Who will be first to tell me what it is? Quote
Marauder Posted September 12, 2016 Report Posted September 12, 2016 See attached. I had been hearing a rattling/clanging noise and found the culprit under the rear seat cushion. Who will be first to tell me what it is? Clip for holding hats. Goes above the baggage area. Sent from my iPad using Tapatalk 1 Quote
Marauder Posted September 12, 2016 Report Posted September 12, 2016 At least it holds my baseball caps. Sent from my iPad using Tapatalk Quote
Marauder Posted September 12, 2016 Report Posted September 12, 2016 It's actually for hanging hangers. Sent from my iPad using Tapatalk Quote
Hank Posted September 12, 2016 Report Posted September 12, 2016 Yep, it goes in the ceiling in front if the hat rack, and in old ads was used to hang your sport coat while you were flying,so you could be presentable and I wrinkled at your destination. The orientation is fore and aft. Quote
carusoam Posted September 12, 2016 Report Posted September 12, 2016 Look for the matching holes in the ceiling... i would hang a couple shirts and coats on them. They would then rest on whatever else was in the baggage hold. If you use them for hanging hats, what is the hat rack for? Best regards, -a- Quote
Immelman Posted September 12, 2016 Report Posted September 12, 2016 That thing helped land my my current airline job: It held the hangar that hung my suit that I wore to the job fair that I flew my Mooney to... sort of has a nice ring to it. 2 Quote
TTaylor Posted September 12, 2016 Report Posted September 12, 2016 Hung my suit bag on mine two weeks ago when I flew out for interviews. Nice to skip our buddies in the TSA when you have important meetings ☺ 1 Quote
Patto Posted September 12, 2016 Author Report Posted September 12, 2016 Thanks guys. Glad it is nothing too important. Quote
BDPetersen Posted September 12, 2016 Report Posted September 12, 2016 Does hanging a hat require a logbook entry? 1 Quote
Marauder Posted September 12, 2016 Report Posted September 12, 2016 1 hour ago, BDPetersen said: Does hanging a hat require a logbook entry? Good question. And on the heels of that rather spirited discussion on yoke mounts, the answer would be "no" unless you glued it to the rack. Quote
HRM Posted September 12, 2016 Report Posted September 12, 2016 15 hours ago, Patto said: Thanks guys. Glad it is nothing too important. I'll take it if you don't want it. P/N 340072 Quote
bradp Posted September 13, 2016 Report Posted September 13, 2016 I put mine back on and gained 5kts. -brad 3 Quote
MARZ Posted September 13, 2016 Report Posted September 13, 2016 On 9/11/2016 at 9:21 PM, Patto said: See attached. I had been hearing a rattling/clanging noise and found the culprit under the rear seat cushion. Who will be first to tell me what it is? You're in bad need of some noise cancelling head sets if you can hear that in flight... Quote
Patto Posted September 13, 2016 Author Report Posted September 13, 2016 Just now, Mike Ropers said: Your in bad need of some noise cancelling head sets if you can hear that in flight... I concur. But, I've sunk all my "spare" cash into keeping the bird airworthy. Quote
orionflt Posted September 13, 2016 Report Posted September 13, 2016 28 minutes ago, Mike Ropers said: You're in bad need of some noise cancelling head sets if you can hear that in flight... Or he has a really quiet plane! Quote
HRM Posted September 14, 2016 Report Posted September 14, 2016 17 hours ago, Mike Ropers said: You're in bad need of some noise cancelling head sets if you can hear that in flight... He's in bad need of hitting it with some Rustoleum or a Brillo pad if he wants to go au naturel. Quote
Danb Posted September 14, 2016 Report Posted September 14, 2016 On September 11, 2016 at 10:35 PM, carusoam said: Look for the matching holes in the ceiling... i would hang a couple shirts and coats on them. They would then rest on whatever else was in the baggage hold. If you use them for hanging hats, what is the hat rack for? Best regards, -a- Some of the hats the big M needs are quite large 1 Quote
