  • 2 weeks later...
Steve
I can't be certain this will solve your problem..but believe you should be able to locate a workable one from any bone yard that will let it GO
this part in my 91J was made by Sigma Tek ING from Agusta , Kansas  although my J is a 28 volt the picture you sent has the same part number as my 28 v so be careful when you find a replacement to ask voltage
just a tip. Properly mark these wires when removing i.e. As the new or replacement switch may have the label affixed in a different location. ( any questions about this comment give me a call)
my expensive avionics shop messed up my switch installing a garmin radio   Then made the problem worse with error installing the new switch.. A friend and I spent 2 hours trying to figure why the new part Wud not work
we finally got with someone that was familiar and got it correct in one minute.
P 832.655.4203
