My FF tends to bounce around, like 7.6-7.8, as reported by my JPI.
Is this something to be worried about?
Nope (or at least I hope so). My does as well.
Check the installation of the transducer. It must be level. That is, the inlet and the outlet are to be the same height. Also it must be upright in that the wires come out the top. Make sure that the fittings into the transducer don't leak. Check the connector to the transducer, they come with the molex connectors which have the tendency for the female pins to spread. Any signs of the above is an installation problem. How old is the installation? The transducer itself could need to be replaced.
