Cwalsh7997 Posted May 11, 2015 Report Posted May 11, 2015 Hey guys I am wanting to put a FS450 in the plane but as you see the panel I have little to no room. So I'm wondering what you guys think if I were to take out my Garmin 496 and put the 450 there?? 1 Quote
Aerodon Posted May 11, 2015 Report Posted May 11, 2015 CW, That's a nice panel, is there something behind the flight instruments that prevented them being arranged in a standard six-pack? #1 way to create more panel,space is to install an HSI, and something like a Sandel SN3308 has a host of other functions too. Your 'RHS' is pretty full, it would be easy to replace your EGT with a combined EGT with FF. Not cheap, but has high value in running your engine properly and identifying problems. If you go with JPI it is a major step in the direction of a future 730/830/900 upgrade as a lot of the probes and harnesses are identical. Not all. See Marauder's 830 thread and video. Another way is to install a Shadin FADC and then display fuel and air data on your 430. But you need a heading input from the HSI. Regards, Don 1 Quote
OR75 Posted May 11, 2015 Report Posted May 11, 2015 What I would do is install an Insight G2 and get fuel flow, EGT and CHT . Put the instrument where you currently have the single EGT indicator. 1 Quote
carusoam Posted May 11, 2015 Report Posted May 11, 2015 Add FF, engine monitor and try to leave the GPS Where it is ... The old mechanical tach would be first to go. MP and FP would be next... See if the Insight, EI or JPI can fit in that hole with all the primary instruments(MP,FP,tach) you are looking for. Best regards, -a- Quote
PTK Posted May 11, 2015 Report Posted May 11, 2015 These are all very good suggestions to install an engine monitor. You should definitely strongly consider one. As far as ff it is my preference to have a dedicated ff computer to separate out the ff functions. My airplane came with a 450 and a separate 700. What I did is upgrade the 700 to a big screen 800. I really like this setup having all that info from both instruments in my scan. It's a lot easier to let the engine monitor and the FS450 each do their own thing and display it. The EDM800 has ff on it as well and the 450 is piggybacked on same transducer. Is it an option to put it underneath the engine controls? 1 Quote
Danb Posted May 11, 2015 Report Posted May 11, 2015 A lot of great suggestions it's fun to spend others money, but I'd consider like mentioned go with a std 6 pack or Dynon to utilize your space there's more there than you think ..gook luck..Oshkosh may have some great deals if you can wait. Quote
Browncbr1 Posted May 11, 2015 Report Posted May 11, 2015 I suggest you to go buy some aluminum plate and cut a new panel for the left side. Move the vor/ils head over to the left side under the gps head. Put a GEM with ff under the rpm gauge. Quote
carusoam Posted May 12, 2015 Report Posted May 12, 2015 If you need a new panel piece... We have a supplier for that at MS too. Best regards, -a- Quote
EDNR-Cruiser Posted May 26, 2015 Report Posted May 26, 2015 I had the FS-450 installed in my Mooney and really enjoyed it as probably the most accurate and reliable piece of information in my panel. The accuracy was really awesome... - last year the difference between displayed and actual gas consumption based on the receipts was 6 liters less on 2284 liters consumption in total, i.e. the FS-450 showed a total of 2278 liters which is absolute negligible. Highly recommended! 2 Quote
gsxrpilot Posted May 27, 2015 Report Posted May 27, 2015 What I would do is install an Insight G2 and get fuel flow, EGT and CHT . Put the instrument where you currently have the single EGT indicator. Exactly what I did. Love the GEM G2. Quote
