I have a 1963 Mooney and in great need for the piece that connects the scat tubing to the carb heat on the air box. Also would like inputs on sources for the Carb Air duct as mine was damaged by a muffler malfunction.
There was one on eBay, but they were asking a lot for it. As for the carb air duct, there are a couple of sources out there Lasar being the easiest but you will spend a few hundred $$$ on it.
  On 9/1/2013 at 1:51 PM, N201MKTurbo said:
Find someone with good welding skills
See attached picture. It is the piece that connects to the tube that is welded to the air box.
