docket Posted September 27, 2012 Report Posted September 27, 2012 Ok, here's the deal. My manifold pressure transducer is sick and Mooney does not have one. To add insult to injury they can't get one for 6 months. For a used transducer that works I will pay $1000.00. I know that sounds crazy but the new part will cost $1800. I have the Moritz instrumentation and the Ovations/Eagles between 1999 and 2003/4 used this transducer. If any of you know where there is an Ovation or an Eagle that is being parted out I would appreciate the direction. FYI, the Part No. is SP100-110-25a. It was made by Patriot Systems which has since been acquired by Ametek. Ametek will not work on the part and was totally unhelpful -- they clearly said that they are not interested in supporting Patriot parts and they do not have parts for the unit. I have called Wentworth and LASAR and they didn't have one. So, who wants to make my day? Quote
flight2000 Posted September 27, 2012 Report Posted September 27, 2012 Docket, Have you tried the two air salvage operations in Texas yet? http://www.texasairsalvage.com/main_list.php http://www.asod.com/ And finally, stole this link off of the Vintage Bonanza guys... http://www.vintagebonanza.com/Links_to_salvageyards.htm Sorry, this is the best I can do from Germany for you. Good luck in your search. And here I thought the vintage planes would have issues finding parts, not the newer airframes... Brian Quote
docket Posted September 27, 2012 Author Report Posted September 27, 2012 Already been to those and came up dry. I am really hoping that someone has removed their Moritz gauges and just has the old stuff sitting around. Quote
29-0363 Posted September 27, 2012 Report Posted September 27, 2012 Docket, I don't have quite what you need, but I have a MP Transducer for a 2005 Ovation GX2. It reads: PRESSURE TRANSDUCER MANIFOLD PRESSURE KSP P/N APT-20G-1000-25A S/N 7133-4-245 RANGE 0-25 PSIA MFG DATE 12/05 EXCITATION 5VDC KULITE, LEONIA NJ USA TSO-C45A 1 Quote
cbarry Posted September 27, 2012 Report Posted September 27, 2012 Are you sure it's the transducer? I thought I had a similar squawk on my Eagle 2 (same gauges). In this case it waste tach giving erratic readings. Yet I came to find out it was simply a electrical connection that was solved by replacing the connectors between the mag and gauge. I have found it pays/saves to always check the simple stuff first. Quote
Cris Posted September 27, 2012 Report Posted September 27, 2012 Docket This guy has a complete M20S that he has been parting out. He sold the Moritz guages but he may well still have the transducer. He advertises on ebay http://stores.ebay.com/baspartsales If you can't reach him thru the link pm me and I will find his email. Another alternative is a new engine monitor that is stc'd for egt cht Mp etc. Let us know how it goes. Quote
N601RX Posted September 27, 2012 Report Posted September 27, 2012 An S model is being parted out on E-bay. He doesn't have the sensor listed, but I would call them. If you can't find one pressure transducers are somewhat generic. You will need to know the pressure range it can measure, and the output voltage. Some are mv, volts and current out. There are also a couple of different methods of exciting them. I seriously doubt that Patriot systems really built the transducer. If you can talk Mooney or the company that purchased Patriot into sharing the datasheet for the transducer, it would be pretty easy to find one that would work. Quote
docket Posted September 27, 2012 Author Report Posted September 27, 2012 Docket, I don't have quite what you need, but I have a MP Transducer for a 2005 Ovation GX2. It reads: PRESSURE TRANSDUCER MANIFOLD PRESSURE KSP P/N APT-20G-1000-25A S/N 7133-4-245 RANGE 0-25 PSIA MFG DATE 12/05 EXCITATION 5VDC KULITE, LEONIA NJ USA TSO-C45A that one looks close but .... It looks like the air connection is right. Can't tell about the electrical connection. What does your plug look like under the cap? Quote
29-0363 Posted September 28, 2012 Report Posted September 28, 2012 Docket, The connector has 5 internal keyways, 4 pins and 3 bayonet pins. It reads "DEUTSCH DTK1H-8-4P 11139 0538C. If you need any further info PM me with your email address. :// Quote
vorlon1 Posted May 7, 2022 Report Posted May 7, 2022 On 9/26/2012 at 10:21 PM, docket said: Ok, here's the deal. My manifold pressure transducer is sick and Mooney does not have one. To add insult to injury they can't get one for 6 months. For a used transducer that works I will pay $1000.00. I know that sounds crazy but the new part will cost $1800. I have the Moritz instrumentation and the Ovations/Eagles between 1999 and 2003/4 used this transducer. If any of you know where there is an Ovation or an Eagle that is being parted out I would appreciate the direction. Â FYI, the Part No. is SP100-110-25a. It was made by Patriot Systems which has since been acquired by Ametek. Ametek will not work on the part and was totally unhelpful -- they clearly said that they are not interested in supporting Patriot parts and they do not have parts for the unit. I have called Wentworth and LASAR and they didn't have one. So, who wants to make my day? Same model, same problem, looking for the same part! Any ideas? Quote
PT20J Posted May 7, 2022 Report Posted May 7, 2022 3 hours ago, vorlon1 said: Same model, same problem, looking for the same part! Any ideas? I'm not sure what transducer you need, but it if it is a standard Wheatstone bridge type, Omega makes compatible transducers. Mooney used to have a retrofit kit. I don't believe it's available anymore. But, Omega is easy to deal with and will sell direct. I purchased a transducer from them for my fuel pressure gauge and it worked perfectly. Since I specified it with a pigtail to which I added the Mooney connector, my IA signed it off as an owner produced part. If the one you need is exactly what is in the Mooney drawing, you should be able to use that document as approved data for installation. 940183_20220507_0001.pdf PX309.pdf Good luck, Skip 1 Quote
carusoam Posted May 8, 2022 Report Posted May 8, 2022 Revival of a 10yr old thread… Will earn you extra points if you can get it to flow…. What are you looking for… an MP sensor for an Eagle’s Moritz gauge? There are a few Moritz systems around here somewhere… Best regards, -a- Quote
Niko182 Posted May 8, 2022 Report Posted May 8, 2022 On 5/7/2022 at 6:07 AM, vorlon1 said: Same model, same problem, looking for the same part! Any ideas? I have a full moritz setup for an eagle at home. Quote
vorlon1 Posted May 9, 2022 Report Posted May 9, 2022 After some troubleshooting, we think the problem is the transducer, part no. SP100-110-25a. Thanks all. Will post solution later... Quote
