I designed a visor template for my M20E.  Figure I would share them here if it is useful to you.
You can buy 3mm acrylic glass in any color you want from Amazon.  If you have access to a CNC laser cutter and a 3D printer, you can have your self a pair replacement visor in about 20 mintues.  DM if you need help locating a place with a laser cutter.  The visor clip is designed for visor rod that is 4.7mm.
Visor Clip Flat Tight.stl visor.dxf
  • Thanks 4
  • 2 months later...
Does the torque on the clip screws control the friction/force to rotate the visor? I’m designing one for my 65E that will bolt to the center tube.  I was going to leave the legs of the clip open a few degrees so torquing the screw will increase the friction on the rod.  Downloaded the STL but haven’t opened yet.
The clip is slightly smaller than the visor rod.  Tightening it down will increase friction.  Let me know if you need more friction, I can modify the STL and make it tighter.
On 5/13/2025 at 6:14 PM, N201MKTurbo said:
I just cut them out with a scroll saw.
Yeah, same here.  Used a metal cutting blade and then some sandpaper on the edges.  Our instructor broke ours so I used the two pieces as a template.  And like the OP, I got the sheet online at Amazon.
Corn_Flake, will your mounting allow the visor to swing to the side window?? I have a 64E and need new visors and would like to be able to swing them to the side window like modern cars do.
Thanks,
-mark
Thanks,
-mark
Are your visors mounted on the outside corners of the windscreen or on the center post?
Thanks,
-mark
Yes, I can swing the visor to the side like all new cars.
4 hours ago, corn_flake said:
Outside corners.
Then my visors will fit. I am currently out of stock, but should be able to turn out a few sets in the next few weeks, if you are interested.
PM me or email: muncy-d@hotmail.com
  • 3 weeks later...
The older Es don’t have the welded on boss so I designed a bracket the clamps on the center tube and has a stainless steel rod pushed through.  The visors won’t swing to cover the side glass by its better than now visors.  I used Corn Flake’s clip but tweaked it a little.  $10.00 for the stainless at $20.00 for the plastic.
 don't miss them.  With sunglasses and a ball cap visor I am good.  They seem to get in the way.  Yours and Don's look nice though.
