saltydecimator Posted October 19, 2024 Report Posted October 19, 2024 In NE Colorado. I’m on mainly pew pew forums so you can kinda check up on me… mainly I’m asking if I need to not hurt some parts that folks may want ? inwas gonna cut the tail off for wall art, wings are cut off, so not lot of value. Flaps cut, ones bent. so, not much there, but maybe something someone needs??
hammdo Posted October 19, 2024 Report Posted October 19, 2024 Has a SWTA 201 windshield and covers, that is nice…
takair Posted October 20, 2024 Report Posted October 20, 2024 There are two common locations to remove the tail, so no cutting required. The entire tail comes off with only a few bolts . You will see some covers just below the front edge of the tail. That would also give you nice mounting points and may save the tail in case you find a buyer later for another airplane.
MB65E Posted October 20, 2024 Report Posted October 20, 2024 Hi! I’ll take both main trailing links from above the pivots. Basically I’m after the MLG axels but it’s all one assembly. nose gear doors bent? nose truss assembly? reason for cutting it up? -Matt
Slick Nick Posted October 20, 2024 Report Posted October 20, 2024 That 201 windshield would probably fetch a pretty penny!
M20F-1968 Posted October 20, 2024 Report Posted October 20, 2024 What kind of fuel selector does it have? Is it an H&E. I am interested in it and the flap pump. John Breda
saltydecimator Posted October 21, 2024 Author Report Posted October 21, 2024 So sad , has a brand new pitot cover in the seat back… i’m gonna say the rather the left elevator and the halons may or may not be worth something a little dinged up but if you got a super bad one, it might be better than what you have speech to text sorry I reread this on my laptop and correct errors
saltydecimator Posted October 22, 2024 Author Report Posted October 22, 2024 On 10/19/2024 at 10:39 PM, MB65E said: Hi! I’ll take both main trailing links from above the pivots. Basically I’m after the MLG axels but it’s all one assembly. nose gear doors bent? nose truss assembly? reason for cutting it up? -Matt Yep nlg doors tweaked at best, junk at worst. Will post pics it had an incident in nm while back then someone flew it nw for awhile after bandaging slme probs, then got set down again and was deemed not fit to fly. Then sat in field for while
saltydecimator Posted October 22, 2024 Author Report Posted October 22, 2024 On 10/20/2024 at 4:40 AM, Slick Nick said: That 201 windshield would probably fetch a pretty penny! It’s not intact though? Small crack in center, lower part
KSMooniac Posted October 22, 2024 Report Posted October 22, 2024 The wheels could be worth selling if they're not corroded.
Shadrach Posted October 22, 2024 Report Posted October 22, 2024 I will take the flap pump and actuator off you hands for a reasonable price. They’re not making any more of those. 1
Andy95W Posted October 22, 2024 Report Posted October 22, 2024 If the parking brake valve is marked “4200”, I’m interested. It’s on the cabin side of the firewall above the pilot’s brake pedals.
Joshua Blackh4t Posted October 22, 2024 Report Posted October 22, 2024 Do you still have the wings? And did it happen to have a heated pitot? They are worth a bit. I'd be interested in one.
saltydecimator Posted October 22, 2024 Author Report Posted October 22, 2024 1 hour ago, Joshua Blackh4t said: Do you still have the wings? And did it happen to have a heated pitot? They are worth a bit. I'd be interested in one. yep It did have heated pitot but its sheared off at the weld. Doh!
Shadrach Posted October 22, 2024 Report Posted October 22, 2024 10 minutes ago, hammdo said: Keep the inspection panels! -Don Yup. $30-50 a pop through a salvage yard.
saltydecimator Posted October 22, 2024 Author Report Posted October 22, 2024 Well it’s got engine info guage, end I’m working on pullin the parking brake reservoir and valve, in mirror I’m readin “Mobil 4200” but maybe I’m just “optimistic “ ps I’m not trying to subvert rules here, was trying to “start somewhere”
saltydecimator Posted October 22, 2024 Author Report Posted October 22, 2024 20 minutes ago, Shadrach said: Yup. $30-50 a pop through a salvage yard. Ooof! Ya that’s steep! if anyone wants a desk etc I prob plan to section the wings once I get most of the parts off it are we gonna do like a community vote on price type of thing? I’m not trying to hose anybody, but I don’t want anybody buying them cheap and hosing anybody else ,know what I’m saying? I found right elevator and h stab It’s been sawzalled off so only useful as wall art or maybe internal , OB rip parts or fwd spars…
Andy95W Posted October 23, 2024 Report Posted October 23, 2024 @saltydecimator- if possible, please take a picture of the parking brake valve and reservoir. If it’s the one I’m looking for, I’ll take it and one oval inspection panel (8 hole). Thanks!
Joshua Blackh4t Posted October 23, 2024 Report Posted October 23, 2024 9 hours ago, saltydecimator said: It did have heated pitot but its sheared off at the weld. Doh! Looking at the photo, possibly only the bracket/mount part is broken and the actual element might be ok. If its not obviously broken electrically, it may be repairable. Would be prepared to offer something for all the pitot parts and have a go at fixing it. 1
saltydecimator Posted October 23, 2024 Author Report Posted October 23, 2024 14 hours ago, Joshua Blackh4t said: Looking at the photo, possibly only the bracket/mount part is broken and the actual element might be ok. If its not obviously broken electrically, it may be repairable. Would be prepared to offer something for all the pitot parts and have a go at fixing it. Yeah, I can get some close-ups this afternoon. Do you mean you want the full length of tubing, etc. and the full length of wiring or just attached to it right there at the wing interface? Bad news on the parking brake it’s 4500 A1.
saltydecimator Posted October 23, 2024 Author Report Posted October 23, 2024 Looks like the left two windows ok 1
saltydecimator Posted October 23, 2024 Author Report Posted October 23, 2024 On 10/22/2024 at 2:34 PM, Joshua Blackh4t said: Do you still have the wings? And did it happen to have a heated pitot? They are worth a bit. I'd be interested in one. Ok I will go take pics etc in a lil bit
Andy95W Posted October 24, 2024 Report Posted October 24, 2024 2 hours ago, saltydecimator said: FYI- the 4500 A1 valves sell for a couple hundred $ on eBay normally. 1
