orhepxo Posted December 9, 2023 Report Posted December 9, 2023 What is the inverter in my M20k (252) giving power to? I'm in the middle of the rats nest phase of an avionics upgrade, and I'm trying to determine if it is still needed and cleaning up under the panel (read: the wire from the breaker is cut and I have no idea what is was plugged to). Thanks for for the help. Joe Quote
Aerodon Posted December 11, 2023 Report Posted December 11, 2023 M20K 252 is 28V and the inverter reduces to 14V for aux power adaptor to protect the 'handhelds' you might plug into the cigar lighter. Quote
Aerodon Posted December 11, 2023 Report Posted December 11, 2023 3 hours ago, Aerodon said: M20K 252 is 28V and the inverter reduces to 14V for aux power adaptor to protect the 'handhelds' you might plug into the cigar lighter. Maybe I am incorrect, my electrical drawing shows the inverter CB wire going to the optional autopilot power connector: JK-PL06A, And the Cigar CB is 28V. Aerodon 1 Quote
Pinecone Posted December 11, 2023 Report Posted December 11, 2023 11 hours ago, Aerodon said: M20K 252 is 28V and the inverter reduces to 14V for aux power adaptor to protect the 'handhelds' you might plug into the cigar lighter. Inverters convert DC to AC. They may also change voltae. Quote
LANCECASPER Posted December 11, 2023 Report Posted December 11, 2023 On 12/9/2023 at 9:08 AM, orhepxo said: What is the inverter in my M20k (252) giving power to? I'm in the middle of the rats nest phase of an avionics upgrade, and I'm trying to determine if it is still needed and cleaning up under the panel (read: the wire from the breaker is cut and I have no idea what is was plugged to). Thanks for for the help. Joe If the wire to the breaker is cut it's not being used, so should be removed. If you an snap a picture of who made it and what model it is, it probably corresponds to something King that used to be in the panel but the tech was too lazy to clean it up when doing a panel upgrade. This is one reason you'll get a wide spectrum of quotes from different shops for avionics work. Some shops don't untangle the mess under the panel, just work around it. A good question to ask is do they remove all wiring with everything that's coming out? If they don't I'd pick another shop. Quote
Utah20Gflyer Posted December 11, 2023 Report Posted December 11, 2023 18 minutes ago, Pinecone said: Inverters convert DC to AC. They may also change voltae. I thought an inverter changed DC to AC and a converter changed from one DC voltage to another? Quote
EricJ Posted December 11, 2023 Report Posted December 11, 2023 2 hours ago, Utah20Gflyer said: I thought an inverter changed DC to AC and a converter changed from one DC voltage to another? Converting DC to a higher voltage DC is usually called a DC-DC converter. Going down in DC voltage is usually just a regulator. Quote
Aerodon Posted December 11, 2023 Report Posted December 11, 2023 A converter is just 2 inverters back to back. Given that it probably went to the autopilot connector on my 252 wiring diagram, it could have been for a 26VAC inverter that is used in some autopilot / HSI installations. Or to drive a 14v autopilot computer in a 28V airplane. I agree, unused wiring should be taken out, alll the way back to a connector. Mooney has dozens of CPC connectors and with the correct pin remover it is easy to pop them out. And with a full size Mooney wiring diagram, why not mark up what you have done and keep it with the airplane records. Don 1 Quote
Pinecone Posted December 12, 2023 Report Posted December 12, 2023 20 hours ago, Aerodon said: And with a full size Mooney wiring diagram, why not mark up what you have done and keep it with the airplane records. Don I would LOVE to have a full size wiring diagram for my plane (252) Quote
Aerodon Posted December 12, 2023 Report Posted December 12, 2023 19 minutes ago, Pinecone said: I would LOVE to have a full size wiring diagram for my plane (252) Yeah I thought about the ambiguity when I wrote that - I meant the 'original paper size', not a scaled down version. I did see a full size wiring diagram at the cub crafters factory, complete with 'photos' of each connector, spice and terminal. The wires were pulled in place on a pegboard over this drawing and the tech reached alongside him to grab terminals etc. The first harness took 11 hours to make, and it wasn't long before it was down to 3 hours. Different topic, but I agree with Derek Boxwell that avionics shops should have a few spare trays and pre-wire avionics stacks before even ordering the expensive stuff. Makes no sense to have $80 to 100k of avionics on the shelf will plodding through building up a harness. And makes no sense waiting for the customers plane to arrive before starting. The 'good shops' get the avionics harness substantially complete on the bench, and then bring the customers plane into the hangar for the last 2 weeks. Aerodon Quote
jlunseth Posted December 12, 2023 Report Posted December 12, 2023 On 12/9/2023 at 9:08 AM, orhepxo said: What is the inverter in my M20k (252) giving power to? I'm in the middle of the rats nest phase of an avionics upgrade, and I'm trying to determine if it is still needed and cleaning up under the panel (read: the wire from the breaker is cut and I have no idea what is was plugged to). Thanks for for the help. Joe Don’t forget, if you yank it, a new W&B may need to be created. That is one reason why stuff is sometimes left behind that is no longer needed (so the W&B does not have to be modified). The math is not that hard, but I believe it does require a sign off. Quote
Hank Posted December 12, 2023 Report Posted December 12, 2023 33 minutes ago, jlunseth said: Don’t forget, if you yank it, a new W&B may need to be created. That is one reason why stuff is sometimes left behind that is no longer needed (so the W&B does not have to be modified). The math is not that hard, but I believe it does require a sign off. If he's removing old avionics and adding new avionics, the W&B will need updating anyway. May as well remove and weigh the old wiring! Quote
PT20J Posted December 13, 2023 Report Posted December 13, 2023 On 12/9/2023 at 7:08 AM, orhepxo said: What is the inverter in my M20k (252) giving power to? I'm in the middle of the rats nest phase of an avionics upgrade, and I'm trying to determine if it is still needed and cleaning up under the panel (read: the wire from the breaker is cut and I have no idea what is was plugged to). Thanks for for the help. Joe Did you once have a KCS 55A? I believe some installations required a 400Hz inverter. @Jake@BevanAviation would know. Quote
Jake@BevanAviation Posted December 13, 2023 Report Posted December 13, 2023 (edited) In some instances the KCS-55A system might have required a power inverter. See attachment for details. KCS-55A inverter.pdf Edited December 13, 2023 by Jake@BevanAviation 1 Quote
