SARNorm Posted April 18, 2023 Report Posted April 18, 2023 What is the best way to relabel worn rocker switch labels? Some of mine are almost unreadable on my 1979 M20J.
PT20J Posted April 18, 2023 Report Posted April 18, 2023 Laser print on clear Avery label sheet, cut out and past on switch and coat with several coats of clear enamel.
ArtVandelay Posted April 18, 2023 Report Posted April 18, 2023 If you have room, use label maker and put labels on panel below or above the switches.
Pinecone Posted April 19, 2023 Report Posted April 19, 2023 Or new, labeled switch rockers are available. Contact @AH-1 Cobra Pilot He had been making Klixon ones. But with the work of a friend of mine, the Mooney community now has ETA one also available.
