As most of you know, we had an off field landing in our Mooney last year. http://www.kathrynsreport.com/2022/01/mooney-m20c-n79396-incident-occurred.html
I acquired the salvage and have many parts available. I've begun the disassembly, and will be posting images of things that are available, but if you have need for a specific part, please reach out even if there is no picture for it. Initially, I will be asking for offers, but as time permits I will eventually put prices and better information on things. Any reasonable offers will be accepted. This is a bit of an "eating an elephant" situation, so I ask for patience and can't guarantee quick turnover, but if you need quick response I will try and prioritize your request.
None of the listed parts has damage from the accident. All were 100% operational on last flight, but have not been tested since. Sales are "as is".
More information or better pictures can be accommodated upon request.
KI-201C CDI
Mooney ASI
Mooney VSI
Mid Continent Altimeter
EGT Gauge
Gauge only, no probe
Electric Powered Vacuum Pump
Vacuum Pump
Vacuum System Parts
Mooney / Grimes Beacon
Worked when removed, but sounds like a coffee grinder.
14VDC to 26VAC Transformer
Voltage Regulator
For 50 Amp Generator
Suction Gauge
Nav Lights
Battery Box
Electrical Rack Shelves
Lower Cowl Induction System / Intake Filter
No damage
Coat Hangar
Rear Seat Flashing
Overhead Control Placards & Knobs
Control Rods Yaw & Pitch
Flight Enhancements Electric Step Actuator
Wing Root Fairing Right - PN 120001 - 6
Retractable Step
Aft Wing Fairing Right - PN 120000-10
Lower Cowl
No damage
Right Elevator
No damage, but some minor trailing edge imperfections
Door
Dent in top, but still seals perfectly
Upper Cowl
Tail Cone Access Panel - PN 913014-501
Misc. Access Panels
Avionics Access Panels
Cowl Cheeks
Airtex Carpeting
Plastic Interior Pieces
Some pieces have minor cracking, many are perfect
Mooney MAP & Fuel Pressure Gauge
Control Tube Ball and Socket Mooney P/N 710001
TO / GA Momentary Button
Control Yoke Shaft, Mooney P/N 720005 Left & Right
Pilot Side Yoke
PTT button in left thumb
Copilot Side Yoke
Original Mooney Gold Console placarding
Rapco Brake Lining 3 pair RA66-111
O-ring AN6230B-6 X 3
Control Yoke Tapered Pin, Mooney P/N AN386-1-10A, 2 used, 1 new
Yolk Assembly, Mooney P/N 710006
Brake Resevoir, Mooney P/N 850006-501 & Parking Brake Valve Asbly, P/N 4200-A1
Jack Shaft Assembly, Mooney P/N 710007 & Tubes P/N 915001
Bellcrank Assembly, Mooney P/N 914016
Gear Down Switch
Gear Down Lock Bracket, Mooney P/N 560046-501
Flap Handle, Mooney P/N 750006
Pilot side air vent eyeball, Mooney P/N #2120 & #1794
Radio Cooling Box, Mooney P/N 810036-1
Baggage Door
Main Gear Left & Right
There could be significant damage to some parts of this assembly due to the off field landing with gear down.
Mooney Brakes
Main Gear Wheel Assembly Left & Right
Hi - If you have them, I'd like to buy: (1) the complete adjustable cowl flap system (I do not need the flaps themselves) - I have a '68 where they were in fixed position and I want to convert them to adjustable.   (2) the metal duct tubes on each side that blow air on your feet on each side and are controlled by a butterfly valve near the end (the butterfly valves in mine a broken).
alas, the air handlers are already spoken for. I might have what you need for the cowl flap system, but I'm not certain it's all together. The cowl was already removed when I got the plane back. I'm pretty sure I have the knob and cable, and probably the pushrods. But, I think part of that system is integral to the engine mount, is it not?
3 minutes ago, chriscalandro said:
How much are those flaps?  Are they straight?
They appear to me to be undamaged other than normal wear and tear. Give me an offer.
2 hours ago, glbtrottr said:
Md200-306, Tom 170c and indicator, and usb - pm me prices pls -
I would greatly appreciate offers. I won't be offended, if we can't agree on value, then we both move on, no harm. I'm still disassembling and trying to organize this mess....
Great job catalogging and photographing , BUT that downlock is SEVERELY worn , throw it in the trash.....   Carry on...
  • 4 weeks later...
Hey there, wondering if you have a few parts available?
Flap master cylinder and slave cylinder
Brake master cylinder
Steering horn and components
Many thanks.
Hey there, what is the best way to organize getting this done and maybe pics of brake cylinders and steering horn/components?  I dont know how to do private messages on here?
I have a fellow named Joyce Ashiow emailing and calling from a Google Voice number… I was getting the feeling that is a scammer, but please let me know if it is you:)
Many thanks.  W
@salty The handle on my baggage door has seen better days... yours looks really good in the pic. Would you be up for taking the handle off and selling?
I would prefer to sell the whole door. Or the door whole. Whichever is more correcter.
Door whole makes me think of something else... :lol: Haha can definitely understand that. If you change your mind, feel free to shoot me a PM.
On 5/11/2023 at 12:20 PM, Jerry Pressley said:
down lock could only have paint problem.  I have half a dozen that look identical and only one has actual metal wear.
Its trashed , Its shaped like an egg , Throw it in the trash, Or give it to Jerry....
I agree with Alan. This downlock block is a gear collapse waiting to happen. It’s quite worn.
Good news is I have a set of up/down lock blocks should someone want them.
