Stetson20 Posted September 23, 2022 Report Posted September 23, 2022 New panel installed. It really highlights how tired the old glareshield is. The avionics guy said it was like holding a cardboard pizza box when he was trying to reinstall it. Any ideas where/who to contact for a new one? TIA Quote
Philip France 13 Posted September 24, 2022 Report Posted September 24, 2022 Hello you may just adjust the brightness level going into menu settings Philip 1 Quote
Mooney in Oz Posted September 24, 2022 Report Posted September 24, 2022 1 hour ago, Philip France 13 said: Hello you may just adjust the brightness level going into menu settings Philip Hello Philip. Stetson is referring to the glareshield, otherwise known as the instrument panel cover. 1 Quote
PT20J Posted September 24, 2022 Report Posted September 24, 2022 Aerocomfort repairs glare shields and covers them with ultraleather. 1 Quote
EricJ Posted September 24, 2022 Report Posted September 24, 2022 Sending it off to get recovered/rehabbed is the usual treatment. I don't know of a replacement source other than a junkyard, and then you'll still be starting with a used one. 2 Quote
201Mooniac Posted September 25, 2022 Report Posted September 25, 2022 Here is one source: https://www.aircraftspruce.com/catalog/appages/mooney201.php?clickkey=68637 1 Quote
Larry Posted September 25, 2022 Report Posted September 25, 2022 The Aircraft Spruce glare shield doesn't have the raised area in the middle. It would require you to modify your panel to use. Send your picture to Hector at Aerocomfort in San Antonio. He should be able to tell you if it can be repaired. I had my glare shield repaired and covered last year by Aerocomfort.. 2 Quote
carusoam Posted September 27, 2022 Report Posted September 27, 2022 Forever planes usually go to Hector at aerocomfort…. He can rebuild it and make it look brand new…. -a- 1 Quote
WAFI Posted September 27, 2022 Report Posted September 27, 2022 He's got one with the hump... 1 Quote
Red Leader Posted October 31, 2022 Report Posted October 31, 2022 Did you get your glareshield replaced? I just replaced my good glareshield with a leather-covered one so the extra one is available for sale. Mine is in good condition with the slot cover and underside lights. PM me if you're interested. 1 Quote
