rocketman Posted September 9, 2022 Report Posted September 9, 2022 During a recent annual on my 1980/1992 231 Rocket I noticed the turbocharger has dent in the housing unit and will need to be repaired(?) or replaced. Anyone know who can help me with this or can sell me a turbocharger?
Fly Boomer Posted September 9, 2022 Report Posted September 9, 2022 4 minutes ago, rocketman said: During a recent annual on my 1980/1992 231 Rocket I noticed the turbocharger has dent in the housing unit and will need to be repaired(?) or replaced. Anyone know who can help me with this or can sell me a turbocharger? Turbine side, or compressor side? And when you say "dent", do you mean an indentation from the outside toward the inside? I'm trying to imagine what could cause that.
rocketman Posted September 9, 2022 Author Report Posted September 9, 2022 Yes - going from out to in and it's on the cold side. The engine was sagging which caused it.
N201MKTurbo Posted September 9, 2022 Report Posted September 9, 2022 You can send it out to a turbo shop, like Main Turbo or ATC. They can replace the compressor housing if nothing else is wrong. If you have an adventurous mechanic, he can probably change the housing.
Fly Boomer Posted September 9, 2022 Report Posted September 9, 2022 4 hours ago, rocketman said: The engine was sagging which caused it. So, the 520 needed new shock mounts? That's a whole bunch of shock mounts. You have my sympathy. I'd be interested in who did it, and how much it cost. No doubt that little job is in my future too. All The Best
carusoam Posted September 10, 2022 Report Posted September 10, 2022 Let’s see if our RayJay guy is around… @tomgo2 Its been a while since I have seen him… but, he was around here just hours ago… He has a lot of knowledge regarding care and maintenance of turbos… and probably some contacts too… Best regards, -a-
Yooper Rocketman Posted September 10, 2022 Report Posted September 10, 2022 19 hours ago, N201MKTurbo said: You can send it out to a turbo shop, like Main Turbo or ATC. They can replace the compressor housing if nothing else is wrong. If you have an adventurous mechanic, he can probably change the housing. Any mechanic who pulls the turbo will need to know how to remove the intake housing. The turbo cannot be removed or installed in one piece. The motor mount cage opening is smaller than the assembled turbo! On removal, the intake is removed from the exhaust and center section, slid left (pilot side) as far as possible, then the turbo is removed sans the intake section. Only after the center/hot section assy is removed do you have clearance to turn the intake section sideways to remove it. The two previously mentioned shops have rebuilt or exchanged turbos for me on the three I've done over my Rocket ownership with about the same life expectancy (about 1,000 hours). If your hours are not near "turbo TBO", I would just replace the housing (and fix the source of the damaged housing). Tom 1
tomgo2 Posted September 10, 2022 Report Posted September 10, 2022 Thank you @carusoam for the page. We specialize in the legacy/vintage airplane RAJAY STCs. Not a lot of experience with the OEM installations. Looks like @Yooper Rocketman knows a thing or two about this particular installation! 2
Lois Posted September 10, 2022 Report Posted September 10, 2022 I was looking for a rebuild or new turbo for my rocket 6 weeks ago. Called multiple locations and was told there is nothing available for months due to a back log of orders. If you find a source please let me know. Thanks, Ted
aviatoreb Posted September 10, 2022 Report Posted September 10, 2022 Ive worked with Main Turbo and I could not have better things to say regarding their quality work but also they are lightning fast: https://www.mainturbo.com 1
Lois Posted September 10, 2022 Report Posted September 10, 2022 I spoke with Gary at Main. He said Hartzell has not produced rebuild kits nor new turbos for 520NBs. The back order list is so long that he didn’t even want to guess at a timeline. RAM in Waco said said the same. 1
Lois Posted September 19, 2022 Report Posted September 19, 2022 Main Turbo is starting to get parts in and may have what you need.
carusoam Posted November 7, 2022 Report Posted November 7, 2022 Question for the good doctor @rocketman above… Best regards, -a-
