Any recommendations on getting a KX 155 serviced.  I think its the display but don't know for sure.  Looks like $2,250 is the going rate to change the display.  I'm in the Southeast and looking for the closest most reputable service center.
Thanks Rick
I sent it To Bevans.  Spoke with Tom and he took me through their repair process.  Sounds like good people to work with!  We'll see soon!!!
Thanks everyone!
Rick
  • Like 6
Mine is missing digits.  I'm going to yank it out of the panel and se if I can get the display off, I bet I can.  If so I'm going to clean jp the contacts, as that's it's main problem.  Before the digits went you could bring them back by tapping on the glass.
For what it’s worth, I had the gas lens on my KX165 switched out with LED ones for about the same price by MidContinent in CA and had a 3-day turnaround time. They painted the raised surface and it looks brand new!
https://www.mcico.com/
My KX165 #2 nav/com usually requires several pushes of the swap button to swap frequency from standby. Is this a common problem?  Cost to fix?
Hmm haven't had that happen to me, but you can get a estimate over the phone with the MidContinent folks. Contact the California folks at Van Nuys.
