Greetings.  I have a 1988 M20K 252 with the MB1B engine.  A couple of months ago, I experienced a catastrophic failure just after liftoff; the #3 head exploded/separate from the cylinder.  Fortunately, I was able to get it back on the ground without further incident.  It was miraculous, particularly considering some of the bonehead decisions I made to get it on the ground!  In the end, any landing where the pilot and passengers walk away is a good landing!!!
Anyway, it caused some damage to the exhaust system.  Most pieces are being repaired/refurbished at AWI (they told me this piece can’t be repaired).  I’ve been trying to find the Transition piece (TCM part# 654877).  No one seems to have one, and if they did the prices are criminal.  I’ve already checked: AircraftSpruce, Aviation Parts, Aircraft Exhaust Systems, Plane Exhaust, Aircorn Welding, AWI, EN Parts, Texas and Dallas Salvage, and Knisley Welding.  No luck so far.
Does anyone have any idea where I might be able to find one?
Pascal J Budge
N33RK
Email: pascal.budge@gmail.com
Pascal J Budge
N33RK
Criminal prices? Welcome to airplane ownership . . Lol
Air Power Inc shows the part number back-ordered, just over $3000. https://airpowerinc.com/654877
You might call Continental themselves and see what the availability is of the part.
I called Air Power too.  Best case is a 97 day lead time, and I was told these days that really means 6 months, IF you can get it.  I called Continental too, and they had the same answer.  Pretty frustrating.
Trying an expanded check with “parts locating services”.
Thanks
Pascal
On 6/14/2022 at 10:04 PM, Fly Boomer said:
I can't find the callout for item 1.
That’s the IPC diagram I used to identify the needed part (that’s one thing I appreciate about the Continental site; you can identify part numbers by engine Serial Number).
Still working on finding a solution!
Pascal
Thanks
Pascal
Try Dan at LASAR to see if they can source one - or check with Paul Loewen to see if he has a used one.
