badcummins99 Posted February 22, 2022 Report Posted February 22, 2022 Need a set of gears mine are wore anyone have a lead? Can't find called Don Maxwell, Lasar. Both a no go.. Quote
Ron McBride Posted February 22, 2022 Report Posted February 22, 2022 Try Top Gun, or other MSC’s. Quote
badcummins99 Posted February 22, 2022 Author Report Posted February 22, 2022 Ok I’ll try them tomorrow. Thanks Quote
Guest Posted February 24, 2022 Report Posted February 24, 2022 The same gear set are used in Piper Comanche gear actuators. I’ve seen known Piper Comanche actuator rebuilders buying Cessna flap actuators at auctions. I assume the gears in these are also the same. Clarence Quote
Greg Ellis Posted February 24, 2022 Report Posted February 24, 2022 You could try swta.net (Southwest Texas Aviation) as well. Quote
carusoam Posted February 25, 2022 Report Posted February 25, 2022 Welcome aboard bc… We have a few pre-flown parts suppliers around here… @Alan Fox @Jerry Pressley @SheryLoewen Dukes gear actuator gears… -a- Quote
Jerry Pressley Posted February 25, 2022 Report Posted February 25, 2022 I have a set if someone knows what rhey are worth Quote
carusoam Posted February 26, 2022 Report Posted February 26, 2022 @badcummins99 see note above… Looks like your ship has come in! Go MS! -a- Quote
badcummins99 Posted February 27, 2022 Author Report Posted February 27, 2022 Jerry what you thinking for price? and do you know if there 40:1 or 20:1 Quote
carusoam Posted February 27, 2022 Report Posted February 27, 2022 Ringing @Jerry Pressley’s bell… (see note above) -a- Quote
Jerry Pressley Posted February 27, 2022 Report Posted February 27, 2022 20/1 i think will check for sure when someone gives me an idea on value Quote
