Q The Engineer Posted December 5, 2022 Report Posted December 5, 2022 Throw pressure to the cylinder you're checking with closed valves and listen into the intake and exhaust. It will tell you everything you need to know. Quote
N201MKTurbo Posted December 5, 2022 Report Posted December 5, 2022 1 hour ago, Q The Engineer said: Throw pressure to the cylinder you're checking with closed valves and listen into the intake and exhaust. It will tell you everything you need to know. You know we are talking about check valves in the turbo oil system. Quote
231MJ Posted November 26, 2024 Report Posted November 26, 2024 Is there a shop that is overhauling the turbo check valves? The spring on the return side check valve is really weak and I suspect it loses tension over time. Should be easy to replace for a shop. I have oil leaking out of the turbo but no oil coming out the exhaust so I suspect the check valve has a slow leak and it's getting by the turbo seals. Turbo oil leak.pdf Quote
N201MKTurbo Posted November 26, 2024 Report Posted November 26, 2024 Humm… that seems like an external leak, more than an internal leak. When they leak internally, they just fill the turbo with oil and it makes a big blue smoke cloud when you start the engine. Quote
231MJ Posted November 26, 2024 Report Posted November 26, 2024 Yea, I agree, a seal leak would fill the turbo with oil and it would blow out on start-up. I'll look again - the only external source could be the inlet line to the turbo and I didn't see a leak there but I'll check agian. Quote
Pinecone Posted November 26, 2024 Report Posted November 26, 2024 UV dye an help track down leaks. Clean the area. Add the dye to the oil (about .5 - 1 ounce), run for 2 - 3 minutes. You may need a hangar to get it out of the sun, but the UV lamp lights up the leak nicely. Quote
231MJ Posted November 26, 2024 Report Posted November 26, 2024 Pinecone, You recommended that in a different thread, so I bought the supplies last week and it's on my list to do this weekend. I'll keep you posted on the results. I hope it's a simple external leak because here are the costs of other possible solutions: turbo rebuild: $5,000-$8,000 turbo check valves (both): $3,000 Scavenger pump gears: $10,000 or more? I'll keep you posted. Quote
geoffb Posted November 27, 2024 Report Posted November 27, 2024 the scavenge line check valve leak will fill up your turbine housing and ultimately leak out the exh pipe, then when you start it, it will blow oil down the right side of the belly not aware of anyone overhauling them and new was $1,280 a couple months ago.... The supply line check valve is a completely different animal than the scavenge 1 Quote
N201MKTurbo Posted November 27, 2024 Report Posted November 27, 2024 The drain line check valve will still work fine with a broken spring if it is rigged vertically with the flow up. Quote
jlunseth Posted November 27, 2024 Report Posted November 27, 2024 I never fly if there is oil on the nose gear during the pre-flight. I saw a drop once, had the airplane go into a shop because of it, the shop said it was normal, we lost oil in the dark after crossing Lake Michigan and got to do an emergency power off landing in Canada. No oil on the nose gear for me. None. Not a single drop. Quote
Jetrn Posted November 28, 2024 Report Posted November 28, 2024 turbo overhaul: $2500, Main Turbo visalia, CA. quick turn around time. starter adapter/ scavenge pump overhaul: $3000, aero accessories of Oklahoma. If you bring the plane to Rio Vista, I'm willing to help look it over. Quote
Pinecone Posted December 1, 2024 Report Posted December 1, 2024 That is not the price I got from Main Turbo a month or so ago. Quote
M20F-1968 Posted December 1, 2024 Report Posted December 1, 2024 10 years ago: Turbo overhaul $1000 Scavenger pump overhaul: $500 John Breda Quote
Pinecone Posted December 1, 2024 Report Posted December 1, 2024 The numbers I got started at $6100. Quote
Ragsf15e Posted Friday at 05:31 PM Report Posted Friday at 05:31 PM On 11/27/2024 at 10:36 AM, N201MKTurbo said: The drain line check valve will still work fine with a broken spring if it is rigged vertically with the flow up. Did you have an instructions/SB/ etc showing how to disassemble, clean, replace O rings, and reassemble the check valves? I'd like to clean out my return check valve before spending the $1400 on a new one, but I'm not sure my mechanic will want to disassemble it? Also, @kortopates was correct about the yellow clamps being specified by TCM. Here's the documentation. I just noticed that mine are the wrong ones (they are the normal black clamps). backorderd new ones from spruce. better check valve clamps M87-14R1.pdf 1 Quote
N201MKTurbo Posted Friday at 06:19 PM Report Posted Friday at 06:19 PM 47 minutes ago, Ragsf15e said: Did you have an instructions/SB/ etc showing how to disassemble, clean, replace O rings, and reassemble the check valves? I'd like to clean out my return check valve before spending the $1400 on a new one, but I'm not sure my mechanic will want to disassemble it? Also, @kortopates was correct about the yellow clamps being specified by TCM. Here's the documentation. I just noticed that mine are the wrong ones (they are the normal black clamps). backorderd new ones from spruce. better check valve clamps M87-14R1.pdf 100.66 kB · 0 downloads There is no magic to taking them apart. Just unscrew them. 1 Quote
shawnd Posted Friday at 11:08 PM Report Posted Friday at 11:08 PM Aviall/Boeing has them in stock for around $1271.42. If you have a shop who still has an account, they can get one for you. Quote
N201MKTurbo Posted yesterday at 02:38 AM Report Posted yesterday at 02:38 AM They are a standard part. They are a mil spec part. Tomgo has parts built to the mil spec for about $500. 2 Quote
