Why do the Continental powered long bodys need all of that framework to cradle the engine? Are K models like that? I would think dynafocal mounts like all Lycoming powered Mooneys would be lighter?
I googled pictures of different airplane models and it seems like if it is a Continental it is a bed mount. Lycoming it is a dynafocal mount. I know there are exceptions but that seems to be the most popular setup.
Few airplanes have one make then the other but one that I found is a Piper Seneca. Seneca 1 has Lycomings with dynafocal mounts, the Seneca 2-5 with Continentals have tube framework to cradle the continental. Why?
There are significant forces being handled by the engine mount...
1) Gravity
2) Thrust
3) A whole bunch of gforces sometimes...
4) A whole bunch of torque sometimes...
For the four cylinder Lycoming... the four bolt dynafocal type mounts seem to be more than adequate...
As the engine block gets longer with an extra pair of cylinders the different style of mount becomes a necessity...
Especially as the forces and the torques increase...
PP guesses only, not a mechanic...
Seems to generally be a Lycoming vs Continental thing.   Most Lycomings are dynafocal and most Continentals have bed mounts underneath, at least in my observation.
25 minutes ago, Mufflerbearing said:
Being such a long block, if the IO550 had just the engine mount at the rear of the engine, the amount of stress from the ARM would be amazing I would think.
I agree, yet Bravos, Saratoga, Comanches hang from the back.
Even the IO-720 hangs from dynafocal mounts.  It does squeeze them out pretty well.
Something to keep in mind, At takeoff there is about 600 Lbs. of pull applied to the front of that engine. Mounting it from the back is better for pulling than a cradle. So is the engine mount optimized for holding up the weight of the engine, or supporting the thrust of the engine? It must do both. But the thrust can be twice the weight of the engine.
That engine gives me a hard on.
Lycoming must have some good engineering for that...
Even Indy cars and other assorted vehicles have used the engine case as part of the vehicle’s structure...
The key words are called ‘fully stressed designs’...
The engine block is designed to handle the various stresses....
PP thoughts only, not an Indy car designer...
7 minutes ago, tmo said:
Imagine a PA30 Twin Comanche with a pair of the 720's ;-)
You guys need to stop talking. All of this large engine talk is like reading a hustler magazine.
Ah yes, the short-lived Twin Comanche 800.
”Fast as hell for an hour and a half”
Meh, only an hour if you forgot to taxi on only one engine:D
  • Haha 2
I thought the twin B with a pair of 310hp IO550s was a lot of power /FF...
I don’t get Hustler, but I do get the turbine edition of AOPA...   very similar... :)
Would a pair of IO540’s @ 290HP each fit the Bill?
Edited by M20Doc
Larry F says “Hey”
"There is no replacement for displacement." --Big Daddy Don Garlits (and your local discount plastic surgeon . . . . )
