Ak47 Posted September 13, 2020 Report Posted September 13, 2020 I have a nice 96 bravo, today departing Madison gear didn’t retract. After some WTFing noticed the emergency extension handle was up. Soooo easy, reset it, and still gear motor starts, CB pops, no retract. Seems to me likely that putting handle back in its home didn’t disengage system. Is this a try again situation or is there a history of this? Don’t want to troubleshoot a gear too much thanks, Quote
carusoam Posted September 13, 2020 Report Posted September 13, 2020 Welcome aboard AK... This is best discussed sitting down... You’re safely on the ground right? And your favorite handguns/AKs are Safely stowed... Are you familiar with dissimilar metals wearing against each other? Lets talk about the brass gear that was altered by the other gears when they failed to mesh... A typical challenge when the E-gear isn’t locked out properly... In this case, better to be on the ground with the gear extended... Time to have that brass gear inspected. PP thoughts only, not a mechanic... there are pics around here somewhere if you want them... Best regards, -a- Quote
Ak47 Posted September 13, 2020 Author Report Posted September 13, 2020 Lordy i hope you are wrong! But thanks. I’ll keep updated. Just weird that one inadvertent kick of emerg handle can cascade Quote
carusoam Posted September 13, 2020 Report Posted September 13, 2020 Keep in mind I am only supplying info that I have read around here... I can be completely wrong at any moment... Good luck, it might only need somebody with a file and good mechanical skills... You saved the big bucks already... no GU landing! See if Andrew has anything to add... @Hyett6420 This should be on a list for Jonnie to consider... under dumb things that can happen to unwitting passengers, not in the know... Best regards, -a- Quote
PT20J Posted September 14, 2020 Report Posted September 14, 2020 Could be as simple as something in the latch cable such as a broken return spring or loose stop. I would jack it up and open the belly and figure out what's up. Maybe @M20Doc has some thoughts? Skip Quote
Ak47 Posted September 14, 2020 Author Report Posted September 14, 2020 Good call. Let’s pray. I’m now remorseful that i have only read and not added to Mooney space. I shall now be deeply involved with my adding as well as asking. I’m on my third Mooney after all! Quote
carusoam Posted September 14, 2020 Report Posted September 14, 2020 There is always room for one more on MS... See if you can add some details to your avatar area... Things like location and current plane are often useful for discussions... Hard to tell where to put this data sometimes, based on the various pieces of hardware (Phones and ipads) used to read MS... What were the three Mooneys you have/had, when did you get your first one? All the important stuff, to get to know something about you... Best regards, -a- Quote
kortopates Posted September 14, 2020 Report Posted September 14, 2020 I've seen them jam, from doing that. You won't know for sure till you drop the belly pan and work the manual retraction cable and lever - it might need a little adjusting. But unless you reset and popped the actuator CB more than twice I really doubt it got chewed up. Plus that won't stop the gear from electrically moving the gear anyway- just prevent it from being manually extended; which is why I suspect its just jammed and still engaged. Quote
Ak47 Posted September 15, 2020 Author Report Posted September 15, 2020 Thanks all! Should have an idea in a week, i have a job that takes me to dc during the week so I’ll have an answer when i can mercifully escape Quote
Cruiser Posted September 15, 2020 Report Posted September 15, 2020 I would put it on jacks and do the manual gear retract procedure, then try the electric again. Quote
carusoam Posted September 16, 2020 Report Posted September 16, 2020 15 hours ago, Hyett6420 said: You called oh master? So the article you are looking for is here https://mooneyspace.com/topic/10747-no-back-spring-in-landing-gear-actuators/page/7/ In it is shows the brass "widget" that the emergency gear lever fits into. If this gear lever is not completely retracted then as you operate the gear normally (via electrics) then it rubs on the £800 widget and wears it away. photo 5 on my post shows the clutch assembly which is the key component to this item if not disengaged correctly. I can see how this would give the symptoms you are experiencing. ie emegerncy is still in place jamming the motor because the ratchet assembly for the emergency gear is stopping it rotating. Take belly pan off, and have a look. its a simple job to do. (well removing the pan anyway.) Removing the acutator is also simple as is taking it apart. but if it is what I think it is then it does not need taking apart just the clutch checked for damage. Enjoy Andrew You are the best, Andrew! AK will be fully prepared for the mystery hiding behind the panel... Hopefully, an easy fix is waiting for him... Thanks for digging up the details! Best regards, -a- Quote
Ak47 Posted September 20, 2020 Author Report Posted September 20, 2020 Ok update. What i feared didn’t happen. Mad thanks to everyone. I opened the belly up and while everything looked fine, the manual engage didn’t disengage. For some reason the wire was in such a way that it couldn’t pull it the last bajillionth of an inch. Freed it from it’s issue, and worked like a charm. Might need a readjustment at annual but was working flawlessly since. Was a gremlin. thanks again everyone. Now my wife won’t have to skip dinner! 1 Quote
kortopates Posted September 20, 2020 Report Posted September 20, 2020 Ok update. What i feared didn’t happen. Mad thanks to everyone. I opened the belly up and while everything looked fine, the manual engage didn’t disengage. For some reason the wire was in such a way that it couldn’t pull it the last bajillionth of an inch. Freed it from it’s issue, and worked like a charm. Might need a readjustment at annual but was working flawlessly since. Was a gremlin. thanks again everyone. Now my wife won’t have to skip dinner!Thanks for the update - thought that’s what it would be.Sent from my iPhone using Tapatalk Quote
carusoam Posted September 20, 2020 Report Posted September 20, 2020 Great follow-up AK! Best regards, -a- Quote
Ak47 Posted September 20, 2020 Author Report Posted September 20, 2020 1 hour ago, kortopates said: Thanks for the update - thought that’s what it would be. Sent from my iPhone using Tapatalk Thanks a ton. You rock 1 Quote
flyer338 Posted September 23, 2020 Report Posted September 23, 2020 I have read, more than once, on Mooneyspace about the emergency gear mechanism being armed inadvertently during loading of rear-seat passengers and preventing gear retraction. I have added an item to my pre-takeoff checklist to check this. 1 Quote
