ijs12fly Posted August 2, 2019 Report Posted August 2, 2019 Team, My heater cable broke on the heater box end in the engine compartment - the end that broke was brittle from age and is unrepairable. Does anyone have options for a replacement cable. My shop called Mooney and a replacement one is $500 - OUCH. I believe the book says the cable is for 1975 - 1977 C models. Not sure if the J shares the same part. Thanks in advance, Steve Quote
KSMooniac Posted August 2, 2019 Report Posted August 2, 2019 It might just be piano wire inside the housing... If that doesn't work, take a pic and measure the length and I'll see if one from my '77 J might match.Sent from my LG-US996 using Tapatalk Quote
7.Mooney.Driver.0 Posted August 2, 2019 Report Posted August 2, 2019 Check with your A&P but i replaced mine with this one https://www.aircraftspruce.com/catalog/appages/a7401.php?clickkey=4047 if the outer sleeve is good i would pull the cable out from the cockpit and slide the new cable into the existing sleeve. Here’s is the bulkhead clamps as well. https://www.aircraftspruce.com/catalog/appages/bowdenclamp.php?clickkey=32140 Hopes this helps. Sent from my iPhone using Tapatalk Quote
Hank Posted August 2, 2019 Report Posted August 2, 2019 There's always McFarland. Send them your old cable and the broken piece if you have it, and they'll make a new one to match what it used to be. Quote
Skates97 Posted August 2, 2019 Report Posted August 2, 2019 This one seems to be indistinguishable to the control cables in my plane for the heater, vent, and parking brake. https://www.aircraftspruce.com/catalog/appages/buttondashctrl.php Quote
47U Posted August 2, 2019 Report Posted August 2, 2019 Give Dan at LASAR a call. He fixed my carb heat cable by replacing the wire and sent it back with a repair station tag on it. It was cheaper and faster than any other alternative (albeit, about 10 years ago). They're on the wrong coast from you, but a cable is small and light enough that shipping shouldn't kill you. Tom Quote
ijs12fly Posted August 2, 2019 Author Report Posted August 2, 2019 (edited) Thanks for the options so far. My A&P wont sign off on the Aircraft Spruce cables as they are not PMA'ed. Mcfarlane and Lasar look like good options. Any suggestions for folks that salvage Mooneys and part them out? Edited August 2, 2019 by ijs12fly Quote
KSMooniac Posted August 2, 2019 Report Posted August 2, 2019 I likely have the cable out of my 77 J since I swapped consoles and stuff from my 81 salvage. It would still be a 42 year old cable, though. I think if you called a Mooney shop like Maxwell, you might be advised that the inner wire is simply piano wire, and you could easily replace it with the outer case still in place and then you'll never have to worry about it for the rest of your life. No need to make it harder or more expensive IMO...it's not an engine control cable which should be replaced with new.Sent from my LG-US996 using Tapatalk Quote
ijs12fly Posted August 3, 2019 Author Report Posted August 3, 2019 (edited) Scott, The Cable is 49" long. Any chance this is what you have from your J? Edited August 3, 2019 by ijs12fly Quote
KSMooniac Posted August 3, 2019 Report Posted August 3, 2019 I'll check! Can't remember if it is in my garage or hangar. I'll try to dig it out this weekend.Sent from my LG-US996 using Tapatalk Quote
